Question about ASUS Eee 1000H Notebook
Horizontal lines across whole screen
Today, when I powered up, horizontal lines gradually appeared across the whole screen and stayed there. If I restart, the do not appear straight away, only when windows is fully loaded. If I turn the screen off and on again they stay away for about a minute. My PC has just ran over warranty. HELP PLEASE!
  • mccallionorl Feb 06, 2010
    What does the inverter look like?!
  • 53 Answers
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Posted on Feb 01, 2010
Balancer repair
Normally horizontal line [a thin vertical line across the center of the screen] fault with CRT based TVs is the fault with its vertical scan output section circuit. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jul 11, 2016 | Televison & Video
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Jun 13, 2008 | Westinghouse TX-42F430S Television
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Toshiba Satelite A105S2617 Power Problem
Hey buy dell laptop. they have some gud warrenty options. They replace hardware for free upto 4 years max if they are faulty.
Dec 20, 2007 | Toshiba Satellite A105 Notebook
Brown horizontal lines sporadically appearing on monitor
I had the same problem. I fixed it completely today. The horizontal lines disappeared. IT IS DEFINETLY THE DEVICE DRIVER. I confirmed my monitor model tyope (dell M783s) and downloaded the specific driver for this monitor.
I had to do these exact steps or did not work.
1) with the problem screen, disabled the display adapter under the Hardware/Device Manager settings.
2) Restart the PC
3) Boot will come up with brown lines still but the screen will low resolution of 600x800.
4) Then I installed the correct device display monitor driver onto the pc. ( you may need to scan for new hardware, then choose the directory with the new hard drive.)
If you need step by step... just reply back.
Dec 02, 2007 | Dell M781S Monitor
Horizontal Black Lines on palmOne z22
hi, sounds like the screen has a bad connection. Are the horiz lines the same shade all the way across?
Apr 24, 2007 | Palm Z22 Handheld
ASUS Eee 1000H Notebook Logo
772 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
