Question about Hotpoint NBXR463EBWW Electric Dryer
Splendid Anybody know were to look up the parts & schematics on a Splendid WD802.Need a motor & pump for one.I do have the number to splendid if I need it but thought Id look for the parts on the web.
  • Anonymous Mar 29, 2009
    looking for parts schematic
  • Hotpoint Master
  • 19,396 Answers
Check first here WD850J.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 06, 2009
Why won't my Splendid Ariston washer spin during a regular wash cycle?
Remove the kick plate from the front of the machine and you will find a removable screw-in bung. Put something underneath to catch water. When you remove it, you will find a plastic toothpick in there which is jamming the pump impeller. The safety feature stops the machine spinning if the pump is not working.
Splendid Ariston Google Search
Jan 03, 2017 | Washing Machines
Where can I find an operation manual for the Olimpia Splendid piu 16???
Enter the following in the SEARCH box on any of the Website Google, Mozilla operation manual for the Olimpia Splendid piu 16??? The answers are there.
Feb 03, 2015 | Heating & Cooling
Olimpia Splendid Doleclima+ Error code 8
take it back to the store you bought it from, it is a board problem.
Jun 25, 2014 | Heating & Cooling
Need manual for fagor splendid
Here is the manual for the Fagor Splendid Pressure cooker!
http://www.hippressurecooking.com/fagor-splendid-pressure-cooker-manual/
Jan 13, 2013 | Fagor Elite/splendid Helper Handle
1982 cm450 ignition
Honda Motorcycle CM450E 1982 ignition coil where is the equivalent part,is Honda sabotageing this splendid machine ? Is anybody making a similar ignition coil ?
Sep 21, 2012 | 1982 Honda GL 400
Splendide Model WD 802 . Would not drain water.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Aug 01, 2011 | Washing Machines
There is an icon at the top pf my monitor that I cannot get to go away. It says Splendid Deco with small icons underneath that say Splemdid off and Splendid on. It sort of bounces from one position to...
You can turn off ASUS Splendid software:
1) Right click on your desktop and select "Properties" to bring up your display properties;
2) Select the "Settings" tab and click on "Advanced" on the bottom right;
3) Select the "ASUS" tab on the top right and then the "ASUS Splendid" tab;
4) Unselect the check box next to "Enable ASUS Splendid"
Learn more from ASUS:
http://www.asus.com/999/html/share/2/icon/137/index.htm
You disable it or unstall the software.
May 20, 2011 | ASUS LCD Monitor
I have a Splendide WD802 and the washer/timer is giving me problems. I beleive the part # is 116102529. Splendide wrote me back saying it is no longer available, but some retailers might still have it. Do...
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to use at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well or solder the connection. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
Apr 02, 2011 | Splendide Washing Machines
Splendide 2000 Model Help Needed
I have the same problem with my WD802 "pre M". I have found this forum and it as helped me some. Here is one forum that might help you - http://applianceguru.com/forum2/17215.html - I think it's my control module, but I cannot find a test guide for my "pre M" WD802 module. I am Calling Splendide first thing tuesday to see if they have a tech manual for the "Pre M" models. Good luck with your WD802.
Jun 29, 2010 | Splendide 2000S Front Load Washer / Dryer
Kariba WD 802, need a part number for the Wash/Dry Selector Timer. The machince works properly when manually rotating the timer, it will not advance on it's own.
head over to repairclinic.com and enter your model # for a complete parts list.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Splendide 2100 Vented Washer-Dryer
Hotpoint NBXR463EBWW Electric Dryer Logo
539 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
