Question about Freezers
Maytag chest freezer mqc1557aew not freezing
I moved the power cord to a new plug and a few days later noticed problems. i checked the power and am getting 124 hot to neutral and hot to ground so I feel that it's not a power problem. the compressor runs (seems not to shut off) and at times it cools (when set to 7 down to almost 0 F) then over night warms up to 34 degrees and there's water drops on the inside vice frost. it's a june 2004 model mqc1557aew. hate to junk it but I can't afford to give all my food away when it decides to thaw out. any suggestions on testing or replacement of parts? the liquid and suction lines are a bit cold and slightly warm but I expected a bit more in terms of temp of each line. should the liquid line have condensation in a humid area? Mine doesn't. Thanks for the help. robert.sorenson2@va.gov
Idiot alert!
Seems I moved the plug to a switched outlet in a dark room. Every time I went in the unit was running and everything seems to be fine except the temp was rising....always worse after an overnight without a light on! I tested the power (can't do that in the dark) and checked the freezer over without finding issue.
My stupidity resulted in cookouts for all my friends three nights in a row and a bruised ego......at least my friends think I am a great guy and a good cook! I was rolling the unit to the curb when it dawned on me! Thanks
Posted on Feb 19, 2008
Kelvinator Model UF 510 caught fire on top of the compressor. Is this a common failure.
No, It is very unusual for a freezer compressor to catch fire...while they can run very warm alot they do not get that hot unless there is the failure of a couple of things at once..
heatman101
Mar 04, 2010 | Maytag 14.8 cu. ft. / 419 liter Chest...
Moving, CA to Florida and want ot load a chest freezer on its end
You could expect internal compressor oil to flow into areas which would restrict refrigerant flow, resulting in no cooling. If you have to ship on end, make sure the compressor end is down !
Jun 07, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
My brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Apr 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Chest freezer not getting cold after moving
IS the compressor running? If so u probably cracked a line and lost the refrigerant charge.
Feb 27, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Maytag chest freezer mac1557aew does not get cold
This can be a number of things, one being a bad compressor/motor.
Does it run at all?
If not, the compressor needs to be looked at.
If you are handy, there may be a wiring schematic in the back to further troubleshoot.
You can trace the wiring from the thermostat to see if there is power at other components.
Feb 20, 2008 | Maytag 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
215 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
