Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
  • Anonymous Mar 19, 2014
    Won't start
Can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Posted on Jul 18, 2010
Do you know how to turn the timer off on the hoover vision hd 1400 spin washing machine
Posted on Apr 03, 2010
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Not working at all. my washer was on working and i heard a big bang and my electrics went off, i turned everything back on and the washer started up again but then stopped and now will not work. when...
The ticking that you hear is probably the timing motor for the dial.
Was the "bang" from outside the house? If so, then a transformer probably blew and hit your house with a power surge. Motor is likely damaged, and will need replacement.
If the bang was inside the house, the capacitor on the motor probably blew (unusual failure mode though), and will need to be replaced, motor is likely damaged as well.
Sep 18, 2010 | Hoover Washing Machines
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
The water does not get pumped out of the machine
The filter is to be found at the bottom front left of washer behind a removeable plastic trim, if you can see a screw in the filter cover, undo this, and turn filter anticlockwise to remove.
If no filter at front, then remove rear panel of washer, and remove large black hose fastened to drum, check for blockage here, and check the pump at the same time.
Thanks
.Please rate my solution;
Nov 08, 2009 | Hoover AAA160 Front Load Washer
My hoover washing machine 1400 spin 8kg hd vision hd
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Mar 02, 2009 | Washing Machines
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Jun 22, 2008 | Hoover H130E Front Load Washer
Washing Machines Logo
4,488 people viewed this question
Top Washing Machines Experts
