I have a honeywell gas heater hanging from the ceiling in my shop Model # uhpa175ae-3 Serial # 6396j03508 The exhaust fan starts, the flame lights and finally the main fan kicks in. Quite often, as soon as the main fan begins to turn you can hear a relay begin to click and the fan surges and stops over and over again, until presumably the overlimit switch kicks in, turns off the flame and tries the process over again. Can you help me?
  • Heating & Co... Master
  • 2,461 Answers
HI clean the flame sensor check out the pressure switch jump this out to see if it lights clean sensor on fan control might be dirty clean heater with air line burners heat exchanger then it might be your limit switch but this help doing this other work first
Posted on Feb 01, 2010
Honeywell manuals
Turn the fan in the ON position to verify you have power to the furnace. If the fan turns on, turn it back to AUTO. Pull the thermostat off the wall to get to the low voltage wiring. If you have a gas furnace, pull the red & white wires off and pinch them together. If the furnace starts, the thermostat is bad. If it doesn't start, then begin looking for flame roll out switches in the furnace burner compartment to manually reset. If the furnace inducer (combustion motor starts, & you get no flame, then it is either an ignition problem, or someone didn't pay their gas bill. :0
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
Have Sterling model RF-45-NG, with Honeywell gas regulator SV9500 that will not start. Getting 6 flashes as code. Fans start, ignitor starts.
Clean flame senser first , try jumping out pressure switch , or try jumping out hi leval cut off or low leval cut off , could be air in gas line .
Sep 02, 2011 | Sterling RF45 Propane Gas Heater (45,000...
My mhu45lp mr heater ceiling mount won't start. the green light is blinking steady and exhaust fan is running but burners will not ignite.I did jump the brown and red wires on the pressure switch which did...
Check the electrode is clean and sparking , clean flame sensor and check connections are tight . check hi and low limit switch . check pilot is not blocked .
Jun 24, 2017 | Mr. Heater MHU45LP
My gas house heater turns on, but turns off in a couple minutes. The heat never starts to blow out. Do you know what the probem may be. The piolot light is light and I just replaced to batteries on the...
It could be a few things, dirty pilot assembly, dirty or bad flame sensor or a bad gas valve or loose wire on the gas valve. Watch the flame as it lights to see if all the burners light. If not you will need to clean the burners and flame tray that spreads the flame to all burners. Good luck!
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Sterling rf30 unit heater fan motro cycles on but unit wont fire.
Hi check out the pressure switch jump this out seeif itn lights check flame senser blow heatout with air line hope this helps
Mar 28, 2009 | Sterling RF30 Natural Gas Garage Heater
Rinnai 1004 fa not lighting
This heater needs some back pressure on the exhaust to work so while it is on your bench, take the reducing coupling found on your vent system and put it on the exhaust pipe to restrict the outlet size. Now cycle the heater with the front cover off and with both of the small rectangle viewing ports off so you can see the flame. The heater fan will start to turn closing the contacts on that little square pressure switch. If it does not close you will get this error code. Make sure the small hoses are attached to the switch and the exhaust system. If you hear some clicking going on at the gas valve you can assume that the pressure switch is closing. The gas valve will energize and send gas to the burner. Look for flame. There is a small probe that will sence flame within a few seconds and keep the unit on. If it doesn't, it will turn the unit off within 3-5 seconds. I suspect that a spider has set up shop somewhere within the heater and either restricting the flow of air to the pressure switch, the burner or you may have a bad pressure switch. If you need a switch, I can send you one for $15. Contact me at "the_rinnai-guy@hotmail.com".
Oct 26, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
