Question about Brother MFC-5840CN All-In-One InkJet Printer
About a year ago I lost the ability to print magenta on my Brother MFC5840CN. I found a code to use for a power cleaning and it resolved the problem...does this sound feasible and if so, do you know the procedure.
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC5840 CN Print heads
Stuts,
I guess you have used generic ink carts.
You should buy an original brother ink cart.
When done so make sure all other carts are at full level:
Press menu then start b/k copy then fourtimes arrow up (tel.index). Machine will be in maintenance mode. press 7 then 6 then 4 then start b/k copy. Machine will refresh ink within tubes and print head and do some power cleaning. when finished press 7 then 6 then 3 then start bk copy to run an extra power purge.
Leave maintenance by pressing 9 then 9.
Do run a quality test print.
If you re lucky the ph will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintnenace mode.
If you like to save money refill ORIGINAL Carts by drilling a 2mm hole into the top (O of brother brandname) . You can leave the hole open to refill the cart next time directly without taking it out of the printer.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of destilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
For bk mix 1 ml glycerin alc with 4ml dest. water and 15 ml bk DYE ink (shake well before refill).
This is -nearly- the exacte mixture of original brother ink.
Posted on Mar 02, 2008
SOURCE: Brother DCP-130C refuses to print the magenta ink
If you don't print at least once a month, you will clog the machine. You unfortunately have to get it fixed by a professional or get a new printer. Sorry!
Posted on Jun 14, 2008
SOURCE: Brother DCP 130C not printing magenta and yellow
I had the same problem so i took out all of my cartridges and squeezed them i noticed ha t the ones that worked had ink dripping from a small hole at the bottom and the ones that didnt were blocked so i took a sharp kitchen knife and puntured them... all BETTER! I hope this helps>>>>
Posted on May 26, 2009
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
SOURCE: Brother MFC-235C print head removal
Hi I need help because I have an exam tomorrow and my printer is playing up. I have a Brother MFC 235C. I had a paper jam that I cleared but after the printer reads "printer unable 50" refer to instructions or routine maintenance.
Looking online Magenta printhead often seems to be the problem. I notice that my magena cartridge has split open and is leaking. are they connected? Any thoughts on how I repair it
Posted on Dec 11, 2009
Lines on colored prints
Hi Jam Jam, Try changing the Print Quality from Text to higher print quality.
May 12, 2014 | Brother MFC Office Equipment & Supplies
How to fix print head DCP-165C
Hi luks,
Go To Below Brother Printer Video For Your problem, Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us ForBrother Printer Support
Feb 17, 2014 | Brother DCP 165C Compact Color Inkjet...
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Brother DCP-310CN Magenta not printing
Hello!
Here is the manual to this device.
Please check the troubleshooting part. Hope it will help!
https://manualsbrain.com/en/products/brother-dcp-310cn
Dec 07, 2017 | Brother DCP-310CN All-In-One InkJet...
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
My printer doesint print magenta on test page
Did you use third party ink? Insert a genuine (original) brother ink cart and do the cleaning twice. there should be magenta again. If there is no magenta after that, this could be either because of air in the system (thats why you should do the cleaning twice!) or the nozzels are clogged (and cant be cleaned anymore).
Sep 11, 2007 | Brother MFC-620CN All-In-One InkJet...
Printing problem
Go to MFC5840CN Printer Properties -> Advanced 2. Click on Print processor 3. Select Winprint, then click OK 4. Uncheck 'Keep printed documents', then click OK 5. Go back to Printer Properties -> Advanced again to make sure the option is unchecked.
Sep 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
14 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
