Question about Samsung 52 in. LCD Flat-Panel HDTV
It's taking 3 to 5 minutes for my TV to turn on. When I press the on button on the remote. I hear this popping sound from the TV. It sounds like it is trying to pop on but doesn't. It takes about 25 pops for it to turn on. Do I have some circuit board going bad?
    President:
  • Samsung Master
  • 1,779 Answers
Probably bulging capacitors in the power supply area. Have it serviced ASAP before you end up with high dollar repair.
Posted on Feb 01, 2010
Testimonial: "Thanks..."
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
Need 3 digit code for vizio vsb200 audio bar for a clikr-5 UR5U-8780L-TWM remote
There is no listed 3 digit code. You will have to do a code search. Press and hold the Ok and Aux button for 3 seconds. You will have to press the CH+ or CH- (does not matter which) for upwards of 400 times but the code is in there somewhere between 290 and higher, I lost count. Here are two tips. Move the cable box out of site of the remote and expect the TV to turn off when it hits its code. This will make you think you have found the code as the sound will go off. Don't fall for it. Look at the light on the sound bar only. Once the TV turns off you will need to have it;s remote handy to turn it back on so you will hear the sound again.
Once you pass 290 or so go slow and don't miss the light going out on the sound bar or you will have to do it all over again.
Once you turn the sound bar off press the AUX button again to lock in the code.
It's a pain but the code for Vizio sound bars is in there, don't let them tell you it's not. Took me about 7 tries to find the sequence and make the mistakes but my Vizio bar is now Programmed to the Cliker-5 and works fine. Good Luck.
May 19, 2011 | Televison & Video
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
Won't turn on emediately
Something's out of whack, especially if it does it when manually turning it on. TV repair shop, or new TV. TV's are not usually repairable by anyone but specialists. They are dangerous to fool with otherwise.
Oct 21, 2008 | Televison & Video
Programming my remote to control the sound on my TV
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Jul 24, 2008 | DISH Network IR Remote Control
Power loss reset the timer.
Good Day, Nyung; First try ro reset TV, unplug TV from the wall for 3 - 4 minutes then plug back into wall ac outlet; 2. This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. I hope this was helpful, big IRISH.
Apr 10, 2008 | Mitsubishi WT-46809 46" Rear Projection...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Samsung 52 in. LCD Flat-Panel HDTV Logo
170 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
