Reset tv to factory setup
Had panasonic 42" plasma hd tv about one month when we had short power outage. when tv was turned back on starz (channel 97-1) would no longer display. brighthouse cable provider said it must be quirk in tv because we shouldnt be able to get starz, however we could. when i rerun set for channels it wont pickup 97-1 as available channel. i noticed however that the set for initial set is different then setup displayed now. how can i reset to first time setup and hopefully pick up starz again.
thanks wayne
  • Anonymous Jan 11, 2009
    I bought a Westinghouse LCD TV floor model and I can not get the set to run factory set up. The screen shows "No Signal"
  • Anonymous Mar 22, 2014
    how to reset to factory default. Tv is HD and only allows in setup analog and dvd I need second line for hdm1
    Brigadier General:
  • 6,966 Answers
Most current TV units can be reset to default factory settings by being unplug from the mains fro at least a couple of hours (or overnight).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
"channel not available, no signal" message
on the front of the satellite box, does it have a door that you can open, if so, after opening the door on the inside does it have a red reset button. press the red reset. if no reset unplug for 15 seconds and plug back in. also if its on all channels, and resetting it doesnt work may need to reprogram the satellite. if resetting doesnt work contact satellite provider to reprogram.
Apr 04, 2009 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Feb 09, 2009 | Dell W4200 42 in. HD-Ready Plasma...
I cannot change channels on my HD Dell plasma tv.
have u did a factory reset? menu, settings, fac reset, all settings, passcode 3355. try that
Jan 06, 2009 | Dell W4201C 42 in. Plasma HDTV
Sanyo dp50747 Plasma HD TV
sanyo recommends using the reset button with cable box on, vcr off and press the reset button 2x, then try pressing channel up button if no message appears on the screen. i have not trid it yet... but good luck
Sep 23, 2008 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
NO TV PICTURE
The best way is to contact your service provider and ask them to trouble shoot guide you, there should be a way to reset or diagnose the receiver or if you prefer go back to the place you bought it and ask for a replacement, You should still have the manufacturer's warranty, check that as well.
Aug 13, 2007 | Panasonic TH-50PX75U Plasma HDTV
Plasma TV
Try to reset the TV to factory defaults and see if that helps. Record your color settings and any other setting your have in your config before dong this because all will be lost.
Jul 14, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
1,217 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
