Question about D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater
I can't get to http://192.168.0.30/
Every time I try to begin the configuration for my DWL-G730AP router, when I type the http://192.168.0.30/ in the URL, Gateway and Google tell me they can't find this address and instead give me a list of suggested web pages. My D-Link router instructions say to type the above in the URL and then a page showing where I can put in my username and Password will come up. But, this doesn't happen--the Gateway/Google page comes up instead. Any help would be appreciated. I have a Gateway PC and Windows Vista.
Thanks,
Alice
aihenry@graham.main.nc.us
I bought a DWL-G710 and can't get through IP address 192.168.0.30
I'm using Vista.
My email is bernardo_bur@hotmail.com
Thanks for any help
  • 5 more comments
  • burber Feb 20, 2008
    OK, let's start from scratch. I have a wireless home network by means of a DI-624+ Extreme G and a wireless USB adapter for my desktop. I bought the DWL-G710 to extend the wireless range, this is to get better and faster connectivity accross the different rooms.
    I hoped that two D-Link products will work just plug and play, but to my surprise it did not.
    I can't still connect to 198.162.0.30; the ping would not get response and the ipconfig would return "media disconnected" with two different LAN cables.
    Playing around I could get through the IP address above and complete the Setup Wizzard but with the USB adapter connected to the same desktop. The ping and ipconfig will work fine as well. All I conclude from this test is that the new hardware seems to be working.
    I have a WEP encryption set up with the DI, would this be a problem to set up the range extender? Or may be a problem related to W.Vista?
    I guess I need a complete procedure to set it up. The basic instructions D-Link kit did not help too much.
    Thanks for you help guys. Regards,
    Bernardo
  • mgrantom Feb 23, 2008
    I have the exact same setup and same problem. I am using my laptop with a direct cable to hookup to the range extender. If I give my laptop a static ip address via Network Places right click properties then right click properties on the LAN connection and TCP/IP Properties, set Static IP, then set static IP to 192.168.0.52, subnet mask 255.255.255.0 and default gateway of 192.168.0.30, then , I CAN then "see" the range extender at 192.168.0.30. I can even run the setup wizard. I can even see the range extender appear when I scan for available networks. (It has the same channel, SSID and encryption as the router). Then I can even connect, BUT I cannot get out on the internet. I have wasted about 4 hours on this setup already. I bought this model specifically because I already had a DI-624 router and I wanted to make sure it works. Tech support is totally useless. My question: Should the default gateway on the extender be set to itself (192.168.0.30) or to the routher (192.168.0.1). Thanks
  • Anonymous Jul 08, 2008
    I cant go tohttp://192.168.0.30/
  • Anonymous Aug 24, 2008
    konfigurere
  • Rosalindo Feb 14, 2009
    when I type in the address i get a web search and do not connect
  • letGodwalkwi Apr 28, 2009
    I hook up the Dlink DWL-G710 Model#Dl-524 with my cable internet box. Just the way it says to. But I cannot get my internet to work. So I can go to the ip address.In the cd manuel it tells me to type in http://192.168.0.30 and then hit enter. It says a window will pop up and to type admin for the username. But that window never comes up. Help.
  • Anonymous May 20, 2009
    it doesn't start the connection?
I did this with Windows 7 but the same solution applies to Vista and XP.
1. Connect the Range Extender (mine happens to be the DWL-G710) by cable to your computer. 2. Open the Network and Sharing Center. 3. Click on the connection, then on "Properties" 4. From the list select "Internet Protocol Version 4 (TCP/IPv4)" and click properties. 5. Select "Use the following IP address" 6. Use the following settings: IP Address: 192.168.0.130 Subnet mask: 255.255.255.0 Default gateway: 192.168.0.30 7. Click OK then Close. Give the computer a few seconds to re-establish the connection. 8. Go back to your browser and type 192.168.0.30 again. It will work. 9. Don't forget to go back once you're finished and change the setting back to "Obtain IP address automatically."
Also, it's a bad idea to use WEP encryption as any password you would use is easily crackable within a few minutes using the Aircrack suite of hacking tools in Linux. Even someone using Windows can use a live Linux distribution such as BackTrack which is bootable from a CD to hack in and get your password. Once they have it they're in and use your internet connection.
Use WPA-PSK encyption or better and choose a password that can't be found in any dictionary or on the web. It can't be hacked as of yet.
Posted on Nov 18, 2009
I am running the 624 with the 710 and I can see the 710 from over 300ft away outside. Make sure everything is indentical in the setup. Mine won't work well on WPA, but works well with WEP. Maybe start out open then make the changes one at a time. I had to turn of some of the Internet protection from McAfee to get everything setup. Good luck
Posted on Jul 11, 2008
I had what may may be a similar issue, in that I could get into the wizard, but no changes were saved. I eventually found that if I turned off Windows firewall, I was able to successfully save changes
Posted on May 22, 2008
    Problem Solver:
  • 22 Answers
I assume you are already configure the DWL-G730AP router into http://192.168.0.30/
First try to ping first. go to ms dos prompt, you can go to start and choose run then type cmd (enter).
in ms dos prompt type ping 192.168.0.30
if request time out.
check your ip first, type this ipconfig
make sure that your ip in the same class like 192.168.0.X
for example your ip address 192.168.0.50 then you must be able to reach 192.168.0.30. it must be reply state in ping.
if you ip address in the same class but doesn't reply, then you must check your LAN Cable, try to replace with the new one.
hope this helps you.
Posted on Feb 19, 2008
  • Susanto Wijaya
    Susanto Wijaya Feb 20, 2008
    I'm not sure, but from what i read, it seems your DWL-G710 not compatible with DI-624+ Extreme G. I suggest you to ask first the D-Link technical support to make sure it's compatible or not compatible.
    Please read at this dlink site
    download this document
    and download this too
    be care full when you want to purchase something, make sure you read first the manual and check the compatibility with other current device.
    Scholar:
  • 89 Answers
Usually the default address is 192.168.1.1 Try it and see if it works. Hope this helps. Thanks
2 Suggested Answers
SOURCE: I can't get to http://192.168.0.30/
Every time I try to begin the configuration for my DWL-G730AP router, when I type the http://192.168.0.30/ in the URL, Gateway and Google tell me they can't find this address and instead give me a list of suggested web pages. My D-Link router instructions say to type the above in...
Posted on Sep 13, 2008
I need to reset the Admin settings on my wireless router.
Press and hold the reset button on the back of the router for 15 seconds and it will load everything back to default.
Dec 31, 2010 | D-Link AirPlus G DWL-G730AP Wireless...
DWL-G730AP as a repeater for wireless network
By defaults link to access router with folowing link.
http://192.168.1.1
or
http://192.168.0.1
but if you not able to acess it then reset your router .
Press reset button for 10 seconds it is in back side of router.
Then you can access with above 2 link
Type user name as "admin" and password as "admin" or blank or "password" to access router.
Aug 01, 2009 | Computers & Internet
hi tasosantonio
have you tried ip address. 192.168.0.1
DWL-G730AP
riz.
Jun 27, 2008 | D-Link AirPlus G Wireless Range Extender...
Feb 22, 2008 | D-Link AirPlus G Wireless Range Extender...
Problom
well....don't keep us in suspense...finish the rest of the story...c'mon....Don't do this to us!!!
Feb 12, 2008 | D-Link DI-704P Router
On your machine, go to STARTt>RUN>type in CMD. Press Enter. In the black bix that opens, type ICONIFG.
Look for your IP Address. It should be 192.168.x.xxx. (X can be any number up to 254.) Subnet should be 255.255.255.0. Gateway IP should be 192.168.x.1.
If your IP address is 169.xxx.xxx.xxx, you are not connecting to your router.
Whatever the Gateway IP is, you should put in the addess bar of your IE, to get to your router.
Hope that helps.
Jan 13, 2008 | D-Link DI-704P Router
Dwl g122 not connect with dwl g730ap
how to setup driver d-link DWL-G 122 for windows xp
Dec 02, 2007 | D-Link AirPlus G DWL-G122 (DHDWLG122)...
D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater Logo
4,919 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
