Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Convergence problems I have convergence issues with my Panasonic PT53WX52 TV. I have read that it could be the convergence amp? Can you tell me if the STK392-110 wil work in my TV? How many? From which vender and do you buy the cheapest one, or does it matter?
  • Mark Feb 19, 2008
    Opened up the unit, I have two STK392-110. Am going to order both. I can not read the values of the resisters, they are unreadable. It looks like they are not all the same. Any idea how many and what kind they are? I don't have a schematic.
    President:
  • 4,402 Answers
You need to see whats in your tv first and how many most had 2 some have three
you will see a very large heat sink and the IC attached to it.
Posted on Feb 19, 2008
  • Cary Farah
    Cary Farah Feb 19, 2008
    they range from 1.5, 1.8, 2.2, 2.7, 3.3, 3.9 Ohms. 1Watt
    find schematics here
    http://www.eserviceinfo.com/most_popular...
    https://www.manualsparadise.com/Sho...mo...
    https://www.completeservicemanuals.com/p...
    http://www.user-service-manuals.com/Sony...
    http://www.schematicsforfree.com/
Convergence problem Panasonic PT-53TW53G
First I know this set well, did you pull out the board or the light box to replace the chips?
Convergence problems are usually easy to see...
see attached photos and tell me as much as possible.
SD TECH
Nov 10, 2011 | Panasonic PT-53TW53 53" Rear Projection...
First and foremost, DVD's still play perfectly and the colors are beautiful, perfect and alligned on my PT53WX52. However, on Regular TV-(Cox Cable) every human being appears to be the color similar to...
Replace the cable from your cable box to television. Try one from one of your other cable boxes before buying one, but I highly suspect the actual cable from box to TV is bad
Feb 24, 2011 | Panasonic PT-53WX52 53" Rear Projection...
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
My Panasonic PT53WX52F has a sideways hourglass picture with the green scroll running in an arc with the same red scroll running straight across. Is this the convergence chip you talk about?
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Need to know what convergence chips are in Panasonic PT51HX41E
your model has two STK392-110 CONvergence Cs, you will also most likely need at least a few of the 2.2 ohm 2watt convergence resistors. I am posting a link to the actualrepair kit for your model which contains both Convergence ICs and all 6 of the convergence resistors and they send instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 28, 2009 | Televison & Video
PT53wx52 blue convergence just went out of whack and will not adjust. What to do?
Please replace IC7001 and IC7002 on A board as mentioned in below image of A board.
Part number is STK392-110 and available in Part Store.
Apr 22, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic 47wx53 covergence issues
Is the power indicator flashing three times? If so the Ics have shorted shutting the set down. You will need two STK392-110 convergence ICs. You can get replacement ICs at the following link with free installation instructions.
Aug 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Not the convergence amps (stk-120's)
Convergence amps require B+ voltage to run them...they originate in the power supply and are fuse protected......then
they are fed to current limiting resistors near the IC's....
These devices must be checked......But,the #1 problem is use
of less than first quality IC's......STK392-110's,-120 and-150 can
be upgraded to STK394-160E made by Sanyo.....I use Hitachi
part # CZ 01341 or save money = buy kit with two IC's and some resistors part # X 480293...........read any of my convergence
repair solutions......................T.
Mar 23, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Projection TV PT-47WX49E convergence ...
may not be convergence may be a bad stk for convergence if that style if so try stk
Oct 28, 2007 | Panasonic PT-47WX49 47" Rear Projection...
IC Convergence on a Panasonic PT-51HX43
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Sep 19, 2007 | Panasonic PT-51HX43 51" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
