Question about Pinnacle Studio Ultimate Collection 14 Full Version for PC (82101006371)
No puedo instalar el programa de pinnaccle Studio 14 me PIDE numero de serie de 25 caracteres que se encuentra en el CD-OM o la caja del CD-ROM de la anterior versiĆ³n de estudio, no encuentro el numero que hago
richard191
  • 691 Answers
SOURCE: i need the keygen for oinnacle studio 14 ultimate
Hello
Thank you for using FixYa for your problem
I am sorry but FixYa does not provide that type of information
You must contact The software supplier directly
Sorry about that
We could always forward them your request using the email account and IP address of your computer that you use to access FixYa if that will be of use to you so that they can contact you directly if you wish.
They do take credit card payments
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 24, 2009
SOURCE: I bought a brand new Asus CG5205-AR003 W/Intel
Ok you need to UNZIP this file BEFORE you use it. Then go to the Unzipped file location, and then run the install/setup .exe. get Download, WinRAR this will uncompress/Unzip many formats.
http://download.cnet.com/WinRAR-32-bit/3000-2250_4-10007677.html
Posted on Feb 22, 2010
hawkform
  • 217 Answers
SOURCE: recently bought Flip HD Camcorder and have problem
Hi and welcome,
How did you import the video to your Studio? Is that camcorder connected directly to the usb port of your computer? If so? please try and check this one. Found this on the Pinnacle knowledge base
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=221123&ssdFilterCommunity15=0&ssdFilterCommunity13=0&ssdFilterCommunity11=0&ssdFilterCommunity10=368&ssdFilter_SearchKeyWord=importing+AVCHD&page=1&ssdSearchOperator=0&ssdFilterCommunity3=0&Hilite=importing+AVCHD
Regards,
Posted on Nov 18, 2010
  • 54 Answers
SOURCE: I have a new powerful
Probably a good idea to start off by contacting Pinnacle Systems Support.
Posted on Dec 18, 2010
  • 56 Answers
SOURCE: Pinnacle studio 14 importer has
I have experienced this before with earlier versions of Pinnacle Studio. Sometimes a simple reboot works, other times I had to reinstall the software. Remember to backup all of your existing projects, videos, and pictures before you attempt to reinstall so that you do not lose them.
Posted on Jun 14, 2011
Como puedo programar el control de la Caja de dish network para que apague mi tv lg
Luis, mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Es un placer poder asistirle. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales sientase libre de contactarme directamente a: kimberly.escobar@dish.com
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Aug 24, 2013 | Televison & Video
CONFIGURACION DE DIS POR CAMBIO DE DOMICILIO
Estimado Abel, gracias por tomar el tiempo de contactarnos. Lamento escuchar que este teniendo un problema con la configuracion del receptor. Usualmente cuando uno de nuestros clientes se muda de domicilio nosotros ofrecemos instalacion en el nuevo hogar, enviamos a un technico a que se ocupe de todo, de esta manera nuestros clientes no se tiene que preocupar de nada. Dependiendo del equipo y servicio que usted tenga la antenna debera ser instalada para cierta direccion. Que mensaje le aparece en la pantalla cuando prende el televisor? Me encantaria ayudarle con esto. Por favor contacteme a kimberly.escobar@dish.com con su numero de cuenta y con los detalles en sobre lo que le aparece en la pantalla. Espero escuchar de usted pronto para resolver esto. Gracias por su tiempo.
Mar 12, 2012 | DISH Network IR Remote Control
Como puedo programar un control de remplaso para tv2?
Hola mi nombre es Kimberly Ecobar con DISH Network. Tengo enetendido que necesita programar su control de remplaso con su T.V 2. Para programar el control tiene que hacerlo desde la T.V numero1, cuando usted se encuentre alli tiene que entrar a la pantalla System Info. Esto se puede hacer oprimiendo el boton de Menu 2 veces en el control #1 o tambien oprimiendo el boton System Info enfrente del recibidor, Una vez se encuentre dentro de la pantalla System Info hacia la parte de abajo tendra algo que dice Primary Remote Address y Secondary Remote Address a la par de esto una cajita blanca que contiene un numero adentro. El procedimeinto a programar el control es el siguiente: oprima el boton de SAT localisado en la parte de arriba hasta que los demas botones se iluminen en rojo una vez esto suceda ingrese un numero ente 1-15 (pero diferente al que se encuentra dentro de la caja blanca a la par de Secondary Remote address) y despues el signo de numero (#) seguido por el boton de record. El numero dentro de la caja blanca para secondary remote address debe de cambiar al numero que usted elijio si esto no secede asi intente de nuevo el procedimiento esta vez oprimiendo el boton de record 3 veces. En este link puede encontrar todo el procedimiento y mas informacion en como programar su control http://www.dishnetwork.com/SupportSection/remote-setup. Si tiene mas preguntas o necesita ayuda por favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda.
Feb 12, 2011 | DISH Network IR Remote Control
Tengo un control nuevo de dish y no puedo cambiar los canale no se como programarlo
Mi nombre es Kimberly Escobar, representante de servicio al cliente con DISH Network. Siento mucho que este teniendo un problema programando su control nuevo con el recibidor. El procediminto es el siguiente: primeramente en la television donde esta el recibidor tiene que ingresar la pantalla llamada "System Info" esto lo puede hacer oprimiendo el boton de System Info enfrente del recibidor o puede sacar la tarjeta que se encuentra adrento del recibidor, en unos segundos sale la pantalla System Info. En la pantalla de System Info donde dice "remote address" va a ver una cajita blanca que adrento contiene un numero. Usted va a oprimir el boton de SAT hasta que los demas botones se iluminen rojos, una vez que se iluminen ingrese un numero entre 1-15 (pero diferente al que se encuentra adentro de la cajita blanca) seguido por el signo de numero (#) y oprima el boton de Record 1 vez, el boton SAT debe de iluminarce 3 veces. Trate de usar su control deberia funcionar. Espero esto le ayude tambien puede referirse a este link http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara todo el procedimiento. Si necesita mas ayuda o tiene preguntas por favor contactenos directamente al 1800-333-DISH gracias!
Nov 21, 2010 | DISH Network IR Remote Control
Codigo de radio Honda Civic 2006
manten el boton de encenderlo apretado a la vez marca 1 y 6 te va a dar un num. de serie llama a la honda con ese numero y ellos te diran el codigo
May 31, 2010 | 2006 Honda Civic Hybrid
Muchas gracias mi problemas es que mi presario 700 no reconoce ningun disco duro y ya hsta le he cambiado la tarjeta done va el disco duro montado que puedo hacer, no se apresia ninguna anomalia en la...
Pon tu disco de instalación de Windows en la unidad y reinicie el equipo. Al arrancar, presiona F2 (o F12) y establecer la secuencia de arranque para "arrancar desde el CD" Instalar Windows programa detectará el disco duro e instalar el sistema operativo en ella. Si no lo hace, el disco duro ha fallado.
Mar 29, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Ala hora de instalar me pide numero de serie del produto
ME PIDE EL NUMERO DE SERIE Y AL INGRESARLO DICE QUE ESE NO ES EL NUMERO DE SERIE QUE VIENE EN LA CAJA ES S/N:SVZG06113200N08415 Y DICE QUE ESE NO ES ENTONCES CUAL DIGANME POR FAVOR
Oct 10, 2009 | MSI VOX (ms-8609) TV Input
My activation key file missing
Mensaje de error 'La clave de activacion no es valida' al introducir una clave manualmente en Studio Claves de activacion se utilizan para desbloquear ciertas caracteristicas de su programa (efectos especiales, plugins etc) y se generan teniendo en cuenta el pasaporte de su ordenador.
Si ha formateado el disco duro o esta instalado Studio en un sistema nuevo, tendra un nuevo pasaporte en este ordenador y las claves que tenia antes no funcionaran mas.
Tendra que regenerar e introducir de nuevo las claves de activacion para cualquier contenido adicional (i.e. HollywoodFX pack, Video Effect, Audio Effect o 3rd party plug-in) que ha comprado y desbloqueado antes.
Tambien, si va a instalar una version de Studio mas reciente en otro ordenador (o ha formateado el ordenador), tendra que regenerar las claves para poder utilizarlas con la nueva version de Studio.
Nota: la regeneracion de claves es gratuida.
Las claves de activacion se pueden regenerar realizando el procedimiento descrito a continuacion:
Tiene Studio 12 & 11 (Standard - Plus - Ultimate) y su ordenador tiene conexion al Internet
  • En Studio, click en Ayuda y seleccione Regenerar claves de activacion.
  • Introduzca su direccion de email. Saldra automaticamente el nuevo pasaporte. Tiene que acceptar.
  • Las nuevas claves seran regeneradas e introducidas automaticamente en el programa. Tambien puede imprimir las claves. En su correo electronico recibira un email con las claves.
Tiene Studio 10 (QuickStart - Standard - Plus) o Studio 9 (Standard - Plus) o su ordenador no tiene conexion al Internet.
1. En Studio click en Ayuda -> Mi Pasaporte. Apunta el numero de pasaporte, que es una sequencia de 5 grupos, cada uno con 5 numeros. Como es una sequencia de 25 digitos, muchos clientes prefieren copiar y pegar el numero en el campo del paso 3. Mantenga esta ventana abierta.
2. Vaya a la pagina de desbloqueo para regenerar las claves de activacion.
3. Rellene la pantalla
  • Correo electronico:
  • Pasaporte, manualmente o copiando y pegando el numero en el campo
  • Idioma preferida
Nota: Sus clvaes de activacion seran enviadas al correo electronico. Es muy importante utilizar el mismo email que ha utilizado para registrar su producto. Si ha cambiado el email, tendra que actualizar su perfil y despues regenerar las claves.
Al haber recibido el email con las nuevas claves de activacion, las puede introducir en Studio:
  • En Studio click en Ayuda -> Introducir Claves de Activacion.
  • Escriba las claves en el campo apropriado y despues pulse en Aceptar.
Puede ver las claves de activacion en Ayuda -> Ver Claves de Activacion
Si no puede regenerar las claves de activacion o recibe algun mensage de error, le pedimos por favor que se comunique con el soporte por email con la siguiente informacion:
  • lista de claves que se tienen que regenerar
  • direccion de email utilizada para registrar el programa (si ha cambiado su email, tiene que decir esto tambien y enviar el nuevo email para que el agente actualice su perfil)
  • el nuevo pasaporte
  • numeros de pedido que ha recibido al adquirir las claves
May 07, 2009 | Pinnacle Studio Plus Version 11
CLAVE
La unica soluccion en caso que se perda la llave de usuario de windows es volver a instalar el sistema.
Si tiene Windows XP, antes de instalar Windows intende aceder como administrador. El aceso como aministrador se activa aprietando en sucesion las teclas ctrl alt canc (del) tres veces durante la pantalla que insena los usuarios y pide la llave.
En este caso, como salga la fentana que pide usuario y llave atras de aprietar ctrl+alt+del 3 veces, ponga usuario Administrator, y leje la password vacia.
Si esso no funciona tendra que volver a instalar Windows.
Si usted no formatea el disco duro en la instalacion, no se deberian de perder sus datos.
Feb 28, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Compre un programa de roxio creator 10, pero al tratar instalarlo me pidio un numero de serie el cual ingrese el numero de mi computadora de HP.sin embargo me lo rechazo y no puedo instalarlo, que pasos...
AMigo,
Se supone ese key number viene con tu programa, verica con ROXIO, site, y en support le das la informacion de tu programa, ellos gratuitamente te envia otro key!
good luck
Jun 16, 2008 | Computers & Internet
Pinnacle Studio Ultimate Collection 14 Full Version for PC (82101006371) Logo
153 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Computer Links
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
