Question about Whirlpool ED5FTGX Side by Side Refrigerator
Broken Light anchor
I have a Whirlpool fridge and at the level of the indoor light is the 2nd shelf. Well you guessed it, everything that was pushed back on the shelf and actually broke out the light holder from the back of the fridge. The light workd and the holder is ok but the wall of the fridge is broken where the light and holder snap into the real wall and it won't hold it anymore. What can I do to repair this and stabalize the light. There also is no cover over the bulb aned I can't tell if it had one originally or not.-
    President:
  • Whirlpool Master
  • 2,651 Answers
They do make an epoxy repair kit at whirpool but its about $100, six bucks at the hardware store wpuld get a good tube of epoxy as well. 2317782 thats a part number for the lens cover if your model is ed5ftgx
Posted on Feb 23, 2008
Whirlpool refrigerator model# gs6nhaxvk 06...fridge and freezer works normal, but water dispenser and lights not working and the door ajar alarm is beeps.Please advise.
if your freezer door is not closing properly you will have problem with the dispenser because the light switch activate the dispenser is a safety device checked why your door is staying ajar. can be gasket or what i have seen is that after cleaning the refrigerator the customer don't put shelves in properly causing shelf to push against door
Dec 20, 2014 | Whirlpool Refrigerators
Why is there water on top shelf in fridge
I would guess the fridge is not set level. A small amount of water is normally meant to condense and run down the back of the fridge and then evaporate outside the fridge.
If either the fridge is leaning forward slightly or if anything on the top shelf is touching the back of the fridge, then instead of running down the back of the fridge water may instead end up on the top shelf.
Assuming the fridge is still working in every other respect then this is what I would suspect.
Aug 25, 2014 | Max-Fridge Refrigerators
Replacing brake light above trunk on 2006 chrysler
This is quite a process....
Removal
1) Disconnect and isolate the negative battery cable.
2) Remove the rear shelf trim panel.
3) Disconnect the CHMSL electrical connector (1).
4) Remove the two mounting fasteners (3) to the CHMSL (2).
Installation is opposite of removal.
Rear shelf trim panel
Removal
1) Disconnect and isolate the battery negative cable.
2) Remover the right and left lower and upper C-pillar trim.
3) Remove the nut that secures the center rear seat belt lower anchor to the stud on the floor panel and feed the seat belt webbing back through the opening in the top of the rear shelf panel trim (2) to the retractor.
4) Remove the push-pin fastener (1) that secures the trim (2) to the rear shelf panel.
5) Slide the trim forward to disengage the S-clip that secures the underside of the trim to the to the center of the shelf panel.
6) Remove the trim from the rear shelf panel.
Installation
1) Position the trim (2) onto the rear shelf panel(3).
2) Slide the rear edge of the trim rearward to engage the lens bezel of the center high-mounted stop lamp and far enough to engage the S-clip that secures the underside of the trim to the center of the shelf panel.
3) Install the push-pin fastener (1) that secures the trim to the rear shelf panel.
4) Pull the center rear seat belt lower anchor and belt webbing from the retractor through the opening the the top of the rear shelf panel trim and back down to the stud on the floor panel.
5) Install and tighten the nut that secures the seat belt lower anchor to the stud on the floor panel. Tighten the nut to 34 N m (25 ft. lbs.).
6) Reinstall the right and left upper and lower C-pillar trim.
7) Connect the battery negative cable.
C-pillar trim removal
Seat removal
Hope this all gets it done for you........
Feb 23, 2010 | 2006 Chrysler 300
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Top shelf that covers the sub zero fan fell off
line it up with the posts on the ceiling of the refrigerator with the hooks down when it is even on both sides push it back about 3/4 of an inch and latch the clips. if you look at the side of the cover you will see the notchs on the sides of the cover. hope this helps.
May 05, 2009 | Sub-Zero 690 Side by Side Refrigerator
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool ED5FTGX Side by Side Refrigerator Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
