Question about Vacuums
I am using my Hoover Steamvac FH5001 for the first time. It worked great until I had to empty the dirty water tank and refill the solution tank. Now it will not spray solution. I have double checked to make sure both tanks are inserted correctly, but to no avail.
  • 2 more comments
  • irish2535
    irish2535 Feb 01, 2010
    This is the first time I have used this machine. There was only a 5 minute span between the time I took the tanks off and the time I refilled them. This shouldn't have been enough time for the solution to clog the holes, is it?
  • irish2535
    This is the first time I have used this machine, so there shouldn't be a problem with the line or spray nozzles being clogged. When I emptied the dirty water tank and refilled the solution tank, it was only a 5 minute span.
  • irish2535
    I am using my Hoover Steamvac FH50010 for the very first time. It worked fine until I had to empty the dirty water tank and refill the solution tank. Now it will not spray solution.
  • irish2535
    irish2535 Feb 02, 2010
    Thanks. I will check them
  • 10,319 Answers
Check all o rings to see if they are seated correctl= on the hoses that were disconnected. If not you will not receive suction to spray
Posted on Feb 02, 2010
  • 4,102 Answers
Hi, their is a very common problem with every single make and model of this type of cleaner and the cause is always the same problem.
What has happened is after the first time you used it you should have filled the refill solution tank with warm to hot clean water with no solution you then should have pressed the trigger to clear all the solution out and ensure that all that was coming out of the nozzle is just the warm water.
The problem is that it dont tell you to do this in the owners manual and they dont tell you to do this when you buy them but doing this will ensure this problem never happens again so after every use flush warm to hot water through it by filling the solution tank up with just pure water.
Now the problem you are having is that the cleaning solution has turned to a gel and caused a blockage between the solution tank and the nozzle where the solution squirts out of, now hopefully your is just blocked at the nozzle where the solution comes out of if its not blocked their then you need to work back from the nozzles and follow the pipe back to the tank to remove the blockage this will require you taking the case off to get to the clear pipe running from the tank to the nozzle.
Now if you tip the vac on its back on the floor and look at the nozzles where the solution squirts out of their is usually between 4 to 6 little holes that the solution comes out of now what you need to do is get a long sewing needle and poke it into all of these holes to hopefully remove the solution that has turned to gel causing the blockage.
So poke the needled through these holes a couple of times then fill the solution tank with hot but not boiling water then switch it on and hold the trigger down for about a minute or more if it works then just remember to flush the unit out with pure water after every use.
If how ever it still dont work then leave the hot water in and let it stand for 10min to let the hot water work away at the gel blocking it then try it again.
If after doing this its still blocked then re check the holes where the water comes out and poke the needle back through and try again if still no joy then unplug from the mains and turn the vac on its back then look under neath where the nozzles are and you should see some screws you need to undo these to remove the casing this will then give you access to the pipe that will be blocked once you have done this locate the blockage squeeze the pipe where the blockage is to break up the solid gel keep squeezing untill its all flattened out then put it back together and run some hot water back through the solution tank.
You should now find it is working correctly.
Let me know how you get on or if you need further assistance ok
Posted on Feb 01, 2010
  • paul proctor Feb 02, 2010
    hi, if its the first time its been used then you may fund it will take a couple of minutes for the solution to work its way around the piping system so hold the spray button down for a couple of minutes then let me know what happens ok
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
What setting do I need to have the machine on to **** up the excess water? I want to download the manual but can't seem to find a link to do so, how would I do that?
You should have the vacuum set to Wash/Rinse for all steps in cleaning. Press the trigger to release the cleaning solution and push the vacuum forward. With the trigger still pressed, bring the vacuum back towards you). Then release the trigger and again move the vacuum forward and then back. Repeat the "dry" strokes until the dirty water enters the dirty water tank. Watch the water going through the dirty water tank lid. Empty the dirty water tank if the suction fails or the tone changes. Do more dry strokes after cleaning the entire surface until you do not see more water entering the dirty water tank.
The manual is available from Hoover at the product site: http://hoover.com/products/details/f7411900/max-extract-dual-v-widepath-carpet-cleaner/ . The direct link is here: http://hoover.com/file/592/ .
I hope this helps.
Aug 08, 2011 | Hoover SteamVac F7411-900 Upright Vacuum
The suction stopped working after emptying dirty water and filling up with new water and cleaner
I have an older Hoover SteamVac Supreme #F5815 and I'm having trouble figuring out how to clean the part in the front that the dirty water goes thru before it gets to the tank. How do I clean it?
Mar 06, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Just got spinscrub this afternoon and worked great until had to empty dirty water. Now there is no suction at all. Have tried to find clogs and nothing to be found. Am about to return the damn thing!!!
ok 3 things to check before re-boxing it up.
1) make sure that the lid is on properly. it should go on with the 2 tabs at the front of the machine, then click into place at the back of the machine.
2) when you emptied it, sometimes the dirt channel will fall out. This allows for the suction to go between the dirty tank and the clear channel for the water to be sucked back up.
3) when you remove the dirty water tank again, look down inside the machine for a circular hole. there should be a rubber gasket on it to seal up the tank for your suction. If it has come loose or is missing, retrace your steps between the machine where it was last used and the sink or wherever you dumped out the dirty water.
Good luck,
Mark
Nov 11, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
Recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Mar 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac
in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
We used our Hoover SteamVac F6207-900 for the first time today and it did not suction at all. Please help. It emptied all of the clean water/detergent as I cleaned the carpet, but no dirty water came up...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=639624
Generic problem for all Vacuums
Posted by medglen on Jun 01, 2008
We used our Hoover SteamVac F6207-900 for the first time today and it did not suction at all. Please help. It emptied all of the clean water/detergent as I cleaned the carpet, but no dirty water came up into the empty tank.
Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a clog or a vacuum leak in the vacuum line. The suction should be able to pickup the water into the holding tank for you. So please feel free to contact your local vacuum dealer or you can use a wire coat hanger to try to unclog the vacuum but if that fails contact the factory or your local vac dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 01, 2008 | Vacuums
Steamvac quit spraying
Check the seal that the clean water tank sits on, may have come loose. The filter inside the dirty water tank has been pushed up too far, needs to have a 1/4 in. gap from the top to the top of the filter.
Sep 12, 2007 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
