Trying to get on line using a ps3 with a belkin f5d8235-4 wireless router. Using dsl motorola modem 2210. I get either cant obtain ip address or securty timeout
  • rob_robinson Feb 02, 2010
    Ok will try and post results
  • 4,889 Answers
Thank you for posting your question on Fixya. From what you have described, it sounds like your router has a password set. The password applies to both wireless and wired routers. If you don't know what the password is open your browser and type in 192.168.2.1. You will be prompted for a password. Just hit OK if you have not set an admin password of the router. Click on Wireless on the left hand panel and you will see wireless security options. Click on WPA(WPS) and set a new password. The password in WPA should be 8-63 characters long. Type in the password you want and the old pass(If any) will be disabled. Then try connecting to the wireless network again with your new password.
Let me know if you need more help.
Sai.
Posted on Feb 01, 2010
  • eagle338
    eagle338 Feb 03, 2010
    Sure thing.
    Genius:
  • 1,400 Answers
Hello
Have you entered your routers security key code into the ps3?
Log onto your router type, 198.168.1.1 or 198.168.1.0 on your internet browser.
Find the security tab or page and get the wep or wireless key from the router and enter it onto the ps3 internet setup.
The 198.168.1 is your ip address for your router.
Hope this helps.
Posted on Feb 03, 2010
My new WRT160N Linksys won't connect ATT Motorola 2210 DSL Modem
For AT&T default IP address for the Motorola modem is 192.168.1.254.
Default for the Linksys IP address is 192.168.1.1.
Have you changed either one? For them to work correctly they need to be in different subnets. An IP Address of 192.168.y.xx, where y is the subnet and a different number for each device, usually 0, 1, or 2.
If they are in the same subnet, change the modem'smag-glass_10x10.gif IP to 192.168.0.254 or 192.168.2.254. Once you do this you will need to use the new address to access the modem.
You should make sure the router'smag-glass_10x10.gif gateway is outside the DHCP rage of the modem.
Dec 06, 2010 | Linksys WRT160N Wireless Router
How do I connect it to a motorola 2210 modem
This FAQ is for configuring a BellSouth supplied Motorola/Netopia 2210-02-1006 with a generic third-party router that isn't specifically covered in the existing FAQs. If you have a router that is covered in the FAQs, I suggest you use that FAQ. This initial setup is all that is needed to configure and connect your generic router based network for FastAccess DSL. Any additional setup for features like DHCP IP ranges, port triggering, etc is out of the scope of this FAQ.
This FAQ has 4 Major sections:
Section 1 - Overview
Section 2 - Motorola/Netopia 2210 modem configuration
Section 3 - Third party router configuration information
Section 4 - Connections and power up
•The best configuration for networking a router with the Motorola 2210 is to set the 2210 to "Bridged Ethernet" mode and allow the third-party router to do the routing and DHCP functions. The 2210 is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
Before proceeding both the 2210 modem and third-party router must be reset to default. Despite what the help desk tech tells you, resetting the modem does not put it into Bridged Mode.
• The BellSouth Installation CD and Connection Manager are not required to use this configuration.
• The third-party Installation Wizard CD should not be used in this configuration.
• Since BellSouth assigns static IPs via your username the configurations shown are applicable to both dynamic and single static IP customers.
• You must connect the 2210 directly to the computer's NIC to make the necessary changes before you connect the router, because you will probably be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where the 2210 is connected). Additionally, they may be on completely different subnets. After you have made the changes to the 2210 you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the 2210's PPPoE and DHCP functions. Click here for more information.
•If you encounter any problems simply reset the 2210, connect it directly to your NIC, restart your computer, log into the interface, and start over again.
Section 2 ? Motorola 2210 Configuration
bred.gifStep 1
Verify that NIC cards (wireless or wired) are set to "Obtain IP Address Automatically". Completely power down the 2210 and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the 2210 to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter "192.168.1.254" in the address field to access the 2210 GUI interface.
bred.gifStep 3
Enter your BellSouth Username followed by "@bellsouth.net" in the User ID field. Enter your BellSouth Password in the Password field. Re-enter your BellSouth Password in the Confirm Password field. Click on Next. Update the Auto Calender Update Configuration as desired and click Next. The modem will try to initiate a session and then return to the main menu.
bred.gifStep 4
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the 2210.
Section 3 - Third-Party Router Information
bred.gifStep 5
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the third-party router and then the computer.
bred.gifStep 6
Open a browser session to access the router interface as per the router's user guide. Even though the interface will vary from router to router you must use the following configurations as a basic rule:
- Select Obtain an IP address automatically. Important Note: Use Obtain an IP address automatically even if you ordered a static IP.
- Select PPPoE connectivity. Do not select any other choice, even if you have a static IP.
- Enter your BellSouth Username followed by "@bellsouth.net"
- Enter your BellSouth Password
- Select "Keep Alive" or "Always On" (if available)
- Set "Maximum Idle Time" to "0" which is similar to "keep alive" and "always on" (if available)
- Select a redial or reconnect period of "180 Seconds" (if available)
- Enter "1492" in the MTU Field (if available)
- Save your settings (which will probably restart your router)
Section 4 - Connections and Power Up
bred.gifStep 7
Power everything down and physically connect the 2210, wired or wireless router, and any computer(s).
Pictures by Andy Houtz
bred.gifStep 8
Power up the network equipment in this order:
1) Motorola 2210 Modem (wait for DSL synch)
2) Third-party Router
3) Computer(s)
Open a browser session and go surfing!
bred.gifImportant Additional Information
•The 2210 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Motorola. Since you are using the Netgear to establish the PPPoE session the light will stay off. This is normal.
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network.
bred.gifCool Stuff
An online, html-based menu simulator program is available here. The simulator recreates the Motorola 2210 user interface and provides the ability to navigate menus; just like the real modem interface. It is for simulation purposes only and will not make any changes to your actual modem.
Jun 09, 2010 | NetGear WGR614 Wireless Router
I have a belkin fsd7320 router and dlink 302 and cant get to net
It sound like youe wireless card in the laptop is not configured correctly.
The TCP/IP settings on the laptop's wireless card should be as follows :-
In the wireless card's Properties - TCP/IP
Enablw - Obtain an IP Address automatically
Enable - Obtain DNS server address automatically
This is the same for the LAN card.
Nov 21, 2009 | Belkin Computers & Internet
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
Jun 08, 2009 | Arris SURFboard SB5101 Cable Modem
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 08, 2008 | Computers & Internet
Have belkin wireless/modem router, was using aol but now with the utility warehouse using there uwclub.net service. They sent a thompson speedtouch fixed line modem which we had to connect to get on i.e.,...
Try using a dynamic ip address. I think you only use the static if having problems. Just read this.
A dynamic IP address is assigned to a customer’s modem or router, generally via a remote server (such as our own UWClub server). This provides the user with an IP address from an available pool of addresses every time a connection is made. This is the most common type of IP address for our broadband/Broadcall customers.
Thats off The Utility Warehouse page.
Aug 04, 2008 | Computers & Internet
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
