Question about Gateway (4000779) Motherboard
Laptop will power on but not boot up
Says no tpm or tpm ??? Gateway.
  • 316 Answers
Hello my friend,
Attempt to enter into the bios(pressing DEL while you booting) and then Load Bios Defaults settings.
Posted on Feb 02, 2010
  • marios basileiou
    marios basileiou Feb 02, 2010
    Probably you change something in your Bios or you have updated it and enable this option but your laptop does not support it.
My gateway laptop won't startup. It's taking me to a Insydeh20 utility screen
If unable to boot follow the below steps:
-Remove the battery and Power adapter
-Press and hold the power button for 30-45 seconds (with battery and power still removed)
-Insert just the battery and attempt to boot the laptop.
-Insert just the power adapter and attempt to boot the laptop
This may work I have not tested this as I have not got a gateway laptop
Cliff Cook
Jul 30, 2014 | Computers & Internet
TPM FAULTY OR TPM NOT WORKING
In the BIOS (F2 or del or f1) on boot time at the pc first manufacturer boot screen.
Depending on your pc - there may be an option in the Security section of the BIOS there may be a section for TMP is ON or OFF. You can try set to Off or Disabled.
Otherwise a reset all settings to the "default optimal" settings should clear it.
Dec 21, 2013 | Computers & Internet
My nephhew just bought a gateway w350a t series laptop at auction ,the bios is password protected,does anyone know where the cmos battery is ,i cant find it anywhere. i took off all accessable covers and...
The CMOS battery is attached to the underside of the motherboard. you will need to carefully disassemble the entire laptop to access it. If there is a bios password there is no way to tell if there is an issue with the HDD. I would start with removing the CMOS and then resetting the Motherboard using the reset jumper. You need to look up the board and find where the reset jumper is, probably through a web forum or the manufacturer website. after resetting and replacing the battery, you may still run into issues...the password may be set through a TPM chip. This chip stores the security settings in flash memory. The jumper may reset this also, but I am not 100% on that.
Jun 19, 2011 | Gateway Computers & Internet
How to fix "No TPM or TPM has problem" my laptop only boot repeatedly without entering into windows
Switch on the computer and boot from the windows xp disc when it ask Enter to continew R- to repair please press"R". When it go to command mode after 1 minute press"1" then if it asking password enter the password. Then type this command in the screen. Command is " Chkdsk /p /r " . After the scaning take the cd and type "Exit".
Sep 23, 2010 | Dell Vostro 1510 Laptop
I have a gateway ML6720: gets into BIOS OK, but won't BOOT
Upon starting up your computer keep pressing the F8 key. You will see the repair screen come up. Choose the line where you can use the c:/ prompt so you can do the following
When the black DOS screen appears type in chkdsk /f /r
answer Y and reboot
The computer will run a check and repair on your DOS system
When done in a hour or less reboot and see if it will operate correctly.
It is best to have a system reboot disc handy if this happens again. I would create one on a CD if this fixes your problem
Jul 27, 2010 | Gateway Computers & Internet
Gateway M-6340u laptop won't boot
the gateway hang indicates to things either a bios problem or a failing hard drive,sometimes when hard drives start getting old they take a while to spin up and/or has difficulty finding the boot sector,you also have corrupt files which would indicate a failing hard drive.
Try just restarting your computer the hard drive will already be warmed and spun up so the Gateway screen may pass faster.
Try running this prog to diagnose a failing hard drive,it will run in the background so just uninstall it your drives fine.
http://majorgeeks.com/Active_SMART_d246.html
On the bios side the only thing I recommend trying are loading optimised defaults and Safe defaults.
Mar 26, 2010 | Gateway M6307 Notebook
My Gateway ML6720 laptop will not boot, nor even
any news on this? I have the EXACT same problem.
Feb 23, 2010 | Gateway Computers & Internet
LG laptp booting problum
try starting your laptop in safe mode by pressing f8 during the boot up process
Aug 19, 2009 | Computers & Internet
No TMP or TPM has problem
do you have access to another dvd rom? you might order one and use it to test/ return it if it dosnt work.
you could always use an external rom.
cd/dvd roms have their own firmware (like bios) that could be damaged on yours.
Aug 07, 2009 | Gateway MT3705 Notebook
Gateway M6340U hard drive problem
It sound like memory problem. Change the memory and test if the problem is solved.
Dec 11, 2008 | Gateway M6307 Notebook
Gateway (4000779) Motherboard Logo
232 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
