Question about Sony Playstation 3 (PS3) Console
Video wont display
I recently went from a LCD with HDMI input to a LCD projection with the 5 wire hook up. MY ps3 wont pick up the signal, how do i get it to go into the menu to change the setting?
  • 182 Answers
When you turn it on from standby hold down the power button for over 4 seconds and it runs the optimal setting menu and auto selects the best possible option for the cables you have fitted. hope this helps
Posted on Feb 19, 2008
How do i fix when i hook up hdmi cord and the screen wont display and when i hook up vga it does but i want hdmi for my ps3?
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
How do i hook up my ps3 with tv through hdmi as it keeps goin to blue screen
  1. Connect the PS3 standard composite video connector (yellow RCA plug) to the TV composite input and switch the TV to that input. Leave the HDMI cable connected.
  2. Make sure the PS3 is off. Turn it on and hold the power button until you get two beeps (at least 5 seconds). The PS3 navigation screen should be shown on the TV. If not, switch the TV back to HDMI; the screen should be displayed at 480i resolution.
  3. Go to the settings menu. Select Display Settings, then Video Output Settings, then press the X button on your controller.
  4. The on-screen instruction should be "Select the type of input on your TV." Select HDMI, then press the '> (solid right triangle) button on your controller.
  5. You will be offered the choice of Automatic or Custom settings. Try Automatic first (if there is a problem at the end, start over and pick Custom the second time).
  6. Press the X button. You will get a screen asking you to confirm the changes. Press the X button again to confirm.
  7. You may get a screen asking for the resolution setting. IMPORTANT: if your TV's maximum resolution is 720p or lower, do not pick a higher resolution. The TV may not display properly or may not display at all (blue screen). Pick the highest resolution your TV can display.
  8. Confirm this by selecting "Yes" and pressing the X button.
  9. The settings list should now read Connector Type HDMI; Resolution Standard (NTSC); 480p; 720p; 1080p (if applicable). Press the X button to confirm.
  10. You may be offered a choice of audio outputs; you can use HDMI or something else, depending on your setup. Confirm the setting and press X one more time.
At this point, the PS3 should send its signal to the HDMI port following restart. If your TV has more than one HDMI input, make sure you select the one connected to the PS3.
Mar 12, 2011 | Televison & Video
I have a sony wega KDF42WE655 TV(42 inch). It has a HDMI port I recently bought a PS3 and hooked it up to the TV. With the HDMI port connected I do not get any picture or sound. Attempts of rebooting...
There is a separate IC on the main board that does nothing but process the HDMI signal, basically if your using the cable, AVI or any other input other than HDMI and chances are that is bad, it can be replaced if you have a lot of electronic experience, its a $3 chip but its not easy to replace..I would replace the main board if you can find one, sometimes main boards are hard to find..below is a link to the service manual.
Sony KDF 42WE655 Service Manual
Nov 23, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
Hdmi does not work
go into TV menu and turn the HDMI on. guessing it should be in settings? or Video input.
Mar 07, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Blue ray wont play movies on new tv
Are you sure the tv is 1080p capable? Usually when "mode is not supported" is displayed, it means that the tv can not handle the signal format that is being input to it. If you are using HDMI, then signal formatting is usually handled automatically. If you are using component video, you will probably have to tell the PS3 to step down the signal to either 1080i or 720p.
Jan 10, 2009 | Insignia 37" LCD Flat-Panel HDTV
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Hdmi connection
Hi theromanator ,
Please switch on the ps3, go to the menu and change the video out setting to hdmi. this should solve your problem
Please vote for me if this solve your problem
ramesh22
Jun 07, 2008 | Insignia 37" LCD Flat-Panel HDTV
No input signal hdmi
Are you on the correct video source on the TV
Feb 10, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
