The drawer on my sony cdp502es is sticking, how do I repair it? The player works fine if I gently push the drawer in.
    Problem Solver:
  • 13 Answers
So pull the cover from the unit, inspect all of the parts of the cd transport that move, you may see some dried grease, remove that with alcohol, and relube with small amounts of white lithium grease from a spraycan (spray in a small dish and dab with artists brush). Not sure if this is a beltdrive transport, if it is, then it may be time for a belt kit, available on the web.
Posted on Feb 03, 2010
CD player will not open
Look for a pinhole near the opening of the CD drawer. If there is one, straighten a side of a paperclip and gently push it straight in the hole until you feel resistance. This is the manual open mechanism. Push more until the drawer opens enough to pull the rest of the way out (Player should be unplugged when you try this). Hopefully this restores it, but sometimes this is a result of a belt breaking inside which is much more involved disassembly and repair.
Feb 19, 2018 | Audio Players & Recorders
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
I have a Teac PD-495 CD player. The door will not open - just makes a 'noise' as if it's trying to open the door but can't for some reason. Any thoughts?
Sounds like the door may have something sticky around the edges. Even a little sticky stuff (like from candy-coated fingers...?) can prevent the door\drawer of any CD player from opening.
Try gently "assisting" the door during the few seconds it's trying to open. If it seems like it's not sticking to the housing try the manual eject button.
Depending on your specific device, there should be a very small hole near the door\drawer (Refer to your owners manual for the exact location). It will be just big enough to stick the end of a large paperclip into. Insert the end of a paperclip into the hole and push firmly (make sure nothing is blocking the door\drawer from opening) and the door\drawer should open slightly. Then pull the door\drawer open the rest of the way. If you have to do this, make sure the power is off as the unit might try to close the drawer automatically while you're trying to pull it open.
Once you have the drawer open, inspect the inner surface of the drawer and the area it contacts for anything sticky. Clean with a damp cloth only. Do not spray any cleaner on the unit. If you need to use any cleaners, spray them on the cloth. Clean the area around the inner drawer faceplate and surrounding areas. Let dry for a few minutes then power up and test for operation. It should work fine now.
If not, it may be time to replace this old unit with a new one as repair costs generally exceed the cost of replacement.
Hope this answers your problem. Good Luck!
Dec 04, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
I have an old Sony CD player (CDP-M47) - its probably about 20 years old (or so). The cd drawer has started sticking but with assistance if I can get a CD in it plays o.k. Is it fixable?
do you have to push it slightly for the drawer to go in?
if so then aply some wd40 or other lubricant to any gears or theeth on the drawer
and wd40 works fine with electronics
http://www.wd40.co.uk/index.cfm?articleid=1519
Jan 06, 2010 | Sony CDP-C265 CD Player
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Dvd player not working
the disc may be jammed. try using a paper clip straightened a bit and insert into the little hole in the front of the dvd door. that should release the dvd drawer. if the drawer can not be pulled out because of a disc jam, you can try to close the drawer again and gently shake the dvd player side to side, front to back to jostle the disc back into the tray/drawer. then try the eject button again. failing that, you can try to remove the outer case and that ought to give you access to the disc, and allow you to see where it is relative to the tray.
try that and let me know how you are progressing with this problem
good luck
mark
Dec 29, 2007 | Televison & Video
Cd player stuck
Hi..
It will have to have the coverr taken off and the drawer belt replaced.
Find a stereo repair place.
Nov 23, 2007 | Yamaha CDC-585 5-Disc CD Changer
208 people viewed this question
 Grubhead
Grubhead
