Question about Zebra 105SL Thermal Label Printer
Ribbon out I have a ribbon our error on my 105sl Zebra. Ran calibration procedure and the black area only comes up to about 55 while the ribbon mark is at about 65. Tryed cleaning the sensor with no affect
  • 1 more comment
  • theelf Feb 19, 2008
    New Zebra approved ribbon.
    Problem seems to be with Ribbon sensor. The Ribbon led goes to 170 after the calibration procedure. Can turn it down to 80 and get it to print but goes right back up after calibration.
  • theelf Feb 20, 2008
    Zebra recommended air. I also wiped it off. I took a good look at it and it seems clean. Any recommendations?
    Thanks,
    Decided to forget the autocalibration and do it all manually. Seems like a better option than a new Printer !
    Habit-Forming:
    New Friend:
  • 60 Answers
Zebra 105SL Ribbon Out Error BCTP
You may need to default your printer by powering down, hold the pause and feed keys while powering back on for around 20 sec. You will need to adjust the darkness again as it will be set to 10. Also see the link above.
Posted on Jun 30, 2016
    Genius:
  • 3,587 Answers
New or old ribbon?
Posted on Feb 19, 2008
  • Patrick Michaels
    Patrick Michaels Feb 19, 2008
    yes..that would make sense..the sensor needs to be clear and unobstructed, from ink, particles, paper elements, etc. Do you know how to clean that area out? Do you have a warranty on this?
    got backup for your computer?
  • Patrick Michaels
    Patrick Michaels Feb 20, 2008
    maybe, just maybe, a new printer?
We have a Zebra 105SL thermal printer. When I print to it with any application, the error light and paper out comes on.
Sounds like it may need a calibration. Press the calibration button on the front of the machine.
Nov 28, 2013 | Zebra 105SL Thermal Label Printer
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Zebra 105SL runs out of ribbon, the printer still continues to run, have tried calibration, still not stopping when ribbon runs out
Make sure that you have the printer set for THERMAL TRANSFER printing and not DIRECT THERMAL. It is possible to run the printer in DIRECT THERMAL MODE with the ribbon installed so in that case when the ribbon runs out the printer will not stop.
Regards,
mikeo@acebarcode.com
Jan 20, 2011 | Zebra 105SL Thermal Label Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105sl laebls always come out blank
Power on while holding the pause button for 5 seconds. This should print black bar across the width of the label. If this prints, then check the darkness parameter in your label format or driver. Also check to make sure your ribbon is feeding coated side out. There is a shiny side and a dull side to a ribbon. The dull side should be against the media. If it is leaving an image on the ribbon and nothing on the label the ribbon is either loaded incorrectly or not a zebra ribbon.
Oct 03, 2010 | Zebra 105SL Thermal Label Printer
The Zebra 105sl is not printing fluently. By that I mean it will print two rows of labels, then stop for two rows, then print two rows again. My question is how do I get it to print continuessly without...
1st try to calibrate the machine. It might not like the media (labels) you have in it. Try the basic calibration by going through the menu and print the sensor profile. If that doesn't work, try the media and ribbon calibration option.
Aug 17, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105sl felt paper error
check if the sensors behind the printhead (small metal open case)is on the same position that the uper sensor(black plastic bit with the screw behind the printhead) Run the sensor profile, check if he check the gap.
run manual calibration from the settings.
worst case senario, Reset the printer to Factory defult (Press PAUSE and CANCEL buttons and tun printer on, then relese the butons after 5 secounds.
Jul 06, 2010 | Zebra 105SL Thermal Label Printer
Paper out light comes on at 105sl printer
Dear team
sorry for lating to response to your question amd thanks very much for your help, the answers for your questions as follows:
the date i sent to printer through PC is anumber example( 2w1x326)
I use Thremal Transfre Mediatype
thanks very much
Jun 19, 2008 | Zebra 105SL Thermal Label Printer
105SL PRINTER PAPER OUT PROBLEM
What data you are sending to the printer?Can you post it?
What Mediatype u are using(Thremal Transfre or themal Direct)?
Zebra 105SL Thermal Label Printer Logo
1,672 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
