Question about HP Deskjet 840 InkJet Printer
Printer prints a ghost image
Our printer prints a "ghost" image slightly to one side of all characters, and looks out of focus??
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 73 Answers
The ink carrier was dirty already
Posted on Feb 02, 2010
PRINTED IMAGES SLIGHTLY OUT OF FOCUS SINCE CHANGING PRINT CARTRIDGES
Most printers have a "UTILITY" program that will let you align the print heads. I would start there to correct the problem.
Sep 22, 2014 | HP Deskjet 3052A Wireless e-All-in-One...
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
Towards right hand side of printout, characters ap...
If you are getting a "shadow" behind the text or image it is probably your fuser that is causing the problem. Anytime you see a double image or the print is smearing the fuser (aka fixing assembly) is to blame. You can troubleshoot the problem to see for sure before calling out a technician. Send a one page test print job to the printer. Open the rear "output" tray so that the print job exits the rear of the printer. Watch the paper as it is pulled into the machine. When you see the leading edge of the print exiting the printer open up the front door of the printer. This will of course cause the machine to jam up but its worth it. Carefully remove the toner cartridge. Look at the print on the page still inside the machine. Do you see the same grey image? If not then the problem is the fuser. If you do see the grey image then the problem is the toner cartridge. Stopping the print job in the middle of the printer like that allows you to see what the image looks like before it goes into the fuser. If the fuser is the problem call a tech. It is about a $100 - 150 repair for the fuser depending on the labor rates where you live.
May 20, 2010 | HP LaserJet 1150 Printer
Acer 19 monitor is out of focus, looks like ghost
Try using the manual focus.
Has the monitor been hit or dropped?
Mar 27, 2010 | Acer X193W LCD Monitor
Double printing or 'ghost' images
you need to change your toner opc drums
Dec 13, 2009 | HP LaserJet 1020 Printer
Printed page not clean, faded characters in background of page. Any suggestions? I cleaned the pickup roller.
Have you tried another toner cartridge? And when you say it has faded characters in the background? Does it look like it's reprinting the image kind of? If so, you will need the fuser unit replaced. The fuser is responsible for melting the toner to the paper, when it goes bad it can cause "ghosting" meaning it reprints previous images. A technician would be needed at this point, the part number for the fuser is RM1-1289.
Please let me know if there is anything else you need.
Aug 03, 2009 | HP LaserJet 1320 Printer
I have a Ricoh Aficio 1013 copier that has started to have an area of "ghost" printing in a narrow strip about 2" wide and 4" long on the lower left side of the copies that are being made. It appears to be...
Open the right door is there an image on the drum? (if not) It sounds though that your fuser has toner build up on it and is at end of life. These fusers are harder than most to rebuild so maybe a service call? -Carl
Jul 14, 2009 | Ricoh Office Equipment & Supplies
Out of focus print
check what type of paper you are using if laser paper images bleed and look blurred use good quality injet paper.
Oct 07, 2008 | Epson Stylus C48 InkJet Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Ghost image
Try changing the toner first it's the most common cause for this fault failing this then it is going to be the fuser unit will need replacing as it is worn.
Thanks J
Dec 12, 2007 | HP LaserJet 2200D Printer
HP Deskjet 840 InkJet Printer Logo
252 people viewed this question
Seeker5211
Seeker5211
