Question about Poulan Pro 22" Self Propelled High Wheel Mower
Starts but wont stay on...how many springs are on carb
What do u do when you mixed oil with the fuel in the motor mover tank? Is the machine spoilt?
Posted on Feb 07, 2010
My 2006 suzuki dr200s starts with choke out then revs very high and stays that way. Cleaned carb. What can cause this.
Weak or broken return spring.
Weak or broken main body spring
Idle screw in too far
No slack on the throttle cable.
Jun 16, 2018 | Suzuki Motorcycles
Chainsaw wont stay running
if it starts (maybe idles) but then dies when giving it gas it sure looks like its a carb problem , most likely dirt in the high speed jet , but could be a dirty fuel filter as well and that's inside the fuel tank
Apr 16, 2015 | Stihl Garden
Motor starts good idiols high and stays there
rebuild carb with factory kit..,it sounds like its flooding. Or throttle is stuck wide open..,maybe a bad return spring is broke.
Dec 13, 2014 | Garden
Wont stay running
Clean the carbs. Fuel injector. Replace plugs. Clean oil.
Mar 28, 2014 | 2005 Suzuki GSX-R 750
Truck wont start unless i put gas in carb and once it starts it wont stay running unless foot is on pedle
is this a carb model or a injection and what year and model would be of a help
Nov 12, 2012 | GMC Cars & Trucks
Saw starts, wont stay running unless throttling then bogs and dies. changed pluge, gas, cleaned tiny screen in carb, checked diaphrams.
hi
check the fuel pump(not to be tired)inside the carb.the carb could be out of adjustment
regards savumihai71
Oct 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Wont start. sprayed stater fluid but wont stay running
Your carb needs cleaned out. Tke it off and clean it out well with a good carb cleaner and you should be fine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Feb 06, 2010 | Briggs & Stratton Power Products 5,550...
Mtd ym 21" starts but wont stay running
Just checked my dad's for same problem. First thought is its not getting gas from tank; line is clean and no holes. On his 22" MTD push, i took off the air cleaner housing to expose the carb. Sprayed carb cleaner in carb throat, checked for smooth butterfly valve action, and also cleaned small jet/opening on left side of carb housing. Put it together and it ran perfectly. Don't buy a kit until you at least try this, its cheaper!
Oct 13, 2009 | Mtd 22" Yard Machine Push Mower
Wont start
Hello;
If it starts with ether then you have spark, compression, and air. All you need is fuel. Make sure that you have fuel at the carbs and that the fuel is flowing to the cylinders. Check that the petcock is open and free of debris. Hope that helps;
Thanks;
Rich
RPM Northwest
May 19, 2009 | 1977 Suzuki GS 750
Wont stay stared
try adjusting the idle screw on the carb.
Jan 19, 2009 | 1998 Gas Gas EC 250
Poulan Pro 22" Self Propelled High Wheel Mower Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
