Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I have a Philips-Magnafox projection tV, it was manufactured in 2000. The model # is 9P5511C102 and the Chasi # is PTV836. Whenever I turned it on, it will come on nicely with the pictures on the full surface of the screen. But after about two to three minutes, the picture will shrink to the middle of the screen living about 2" of spaces from all four corners of the original screen. Could you please tell me if there is a kit I can buy to correct this problem. I am a professianal A/C Tech. I think I can fix it if I have the kit for it. My name is Israel, and my e=mail address is Obodun1@aol.com. I will appreciate your help greately. Thanks boss.
  • 1,476 Answers
Being a 10 year old set you could have one of several problems. My first suggestion from what you have told me is you have broken solder connections on the video board. Unplug the unit. Remove the back. Remove each board one at a time, carefully marking each wire plug/jack assembly for proper reassembly. Resolder all connections on each board and reinstall. This will take some time, perhaps an entire day. When all the boards are complete and you are sure it is assembled correctly test it. If this does not solve your problem you probably have faulty electrolytic capacitors. They can dry out with time and cause what you describe. If you are not familiar with them you may have to hire a tech to replace them. Let me know how you make out. If the soldering doesn't cure the problem I could give you more detail and pictures to help you identify the caps and facilitate their replacement.
Either way let me know how you make out.
hardrocko
Posted on Feb 01, 2010
I have a phillips ptv836 the power button lights up no pic or sound why
Check on the site www.tvrepairkits.com for your model. I believe its one of the oines that has a known shinking screen issue...when that issue surfaces one of the other possible symptoms is the TV will just shut down.
Feb 03, 2013 | Philips Magnavox 9P6034C 60" Rear...
Philips projection tv 9p5511c102 will not turn on
you will have to contact the manufacturer 1-866-800-9311
Jun 07, 2012 | Televison & Video
I have a 9P5511c101 philps PTV836 in our shop. How do I adjust the vertical.
That model has no adjustment for vertical unless you are speaking of convergence?
Mar 30, 2012 | Philips Magnavox 9P6034C 60" Rear...
I have a magnavox model 9P5511C102 the picture shrinks.
Replace IC7412 - Part # 932210514682 in the Power Supply section.
Jun 29, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips PTV840 55" rear projection TV
You canget a Factory Service manual from www.magnavoxhelp.com. The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Apr 28, 2008 | Philips 9P5544C 55" Rear Projection...
Posting link to service manual
I just sent the link to your email address if you need me to clarify anything for you just let me know.
Apr 15, 2008 | Philips 43P8341 43" Rear Projection...
Regarding service manual for philips magnavox
You can also get a Factory Service manuals from www.magnavoxhelp.com. The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Feb 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Buttons won't work
You will probably need the service manual for both chassis to straighten that out. I am posting a link where you can purchase one manual that covers the entire series for magnavox PTV 836-PTV 835 it has 2,440 pages. It cost 19.99 and they will email it to you and provide you with free unlimited support that goes with the manual purchase. here is the link if interested in getting the service manual.
http://servicemanuals.vstore.ca/
Jan 23, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
