Question about Dell 1710 Laser Printer
What is a photoconductor? - Dell 1710 Laser Printer
    Scholar:
  • 94 Answers
Otherwise known as the drum kit. Quite often the laser printer will tell you (on the LCD display) that you need to replace the photoconductor, but the price list will have no such thing. It will however usually list a Drum Kit.
Posted on Feb 01, 2010
Hi yes i have a Lanier LD015f. I just received the photoconductor. Hoow do you replace it?.
Hi, you should have received instructions with the photoconductor, but replacing it is pretty straightforward.
To remove the old photoconductor:
- Open the front door and the right side door. - Remove the toner hopper. - Unplug the connector going from the photoconductor into the machine. - Pull out the photoconductor.
To install the new photoconductor:
- Remove all of the tape, paper, and packing materials. - Slide the photoconductor into the slot left empty by the old one. - Attach the connector and route it behind the plastic guide. - Reinstall the toner hopper. - Close the right side door and front door.
If the machine was on when you replaced the photoconductor, it should automatically detect the new one.
Dec 01, 2010 | Lanier UNKNOWN
It show 84 replace photoconductor
84 replace photoconductor on the display indicates that the photoconductor has reached its expected life rating. You may continue to print but will be at risk for developing print quality issues. It is recommended that photoconductor unit be replaced. After replacing a photoconductor unit, you will also need to manually reset the PC counter, Thanks
Sep 22, 2010 | Lexmark Lemark E352DN Laser Printer
How do I install a Lexmark E352DN Photoconductor
Here's an article on How to Change the Photoconductor Unit/Kit on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/aykTXL. This should give you an idea on how to install the photoconductor unit in the Lexmark E352dn printer.
NOTE: If you are replacing your old photoconductor unit with a new one, after installing it you will need to reset the photoconductor counter as well.
Aug 12, 2010 | Lexmark E 352dn Mono Laser Printer
How do I replace the photoconductor where is the menu button to reset PC CNT appears after it is replaced?
Power the printer on and get it to the Ready state. With the printer on and in the Ready state, open the front cover.
Press and hold the Cancel button until all of the lights begin flashing up and down.
Release the Cancel button and close the door. The photoconductor count should now be reset.
To confirm that the photoconductor page count has been reset, it is recommended that you print a menu settings page and check the photoconductor level. Do the following:
With the printer at the Ready status, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
Look for a section labeled Cartridge Information and locate the word Photoconductor under this heading.
Confirm that the photoconductor level reading is either OK or close to 100%.
If the reading is low, try printing 10 - 20 pages. Print the menu settings page(s) again.
Confirm that the photoconductor level reading is OK or close to 100%.
Good luck, Gerrit Jan
Oct 29, 2009 | Lexmark E232 Laser Printer
Photoconductor kit
you must reset the error message; find the explanation in the photoconductor kit package
Sep 29, 2009 | Lexmark E238 Laser Printer
Photoconductor trouble
You will need to get the photoconductor unit replaced.
You can get detailed information about the same from:
ftp://download.epson-europe.com/pub/download/205/epson20540eu.pdf
Sep 11, 2009 | Epson Aculaser C1100 Printer
E511 error code
  1. Check of Photoconductor Unit attachment. Re-attach Photoconductor Unit.
  2. Is the Drum of Photoconductor Unit rotating?
  3. Remove Photoconductor Unit. Turn gear of Photoconductor Unit until silver seal attached to Belt can be seen.Is silver seal dirty?
  4. Remove Photoconductor Unit. Is SENSOR TR-0 attached securely?
  5. Remove Photoconductor Unit. Are there any dirt or foreign bodies on the SENSOR TR-0 surface?
  6. Does the error recur when the power is turned ON?
  7. Remove Photoconductor Unit. The voltage of P416-2 ↔ P416-3 on PWBA MCU is 5 VDC when silver paper or other reflective object comes close to the sensing area of SENSOR TR-0, and is 0 VDC when the object is released?
  8. The voltage of P416-1 ↔ P416-3 on PWBA MCU is 5 VDC?
  9. Disconnect the P/J416 from PWBA MCU. Do all of the wiring below have normal continuity?
  10. Replace MOTOR ASSY P/R.
Jun 19, 2009 | Epson Aculaser C1100 Printer
How do i reset a new photoconductor in lexmark e450dn.
According to Lexmark E450DN service manual;
1. Turn off the printer.
2. Press and hold Checkmark and Right Arrow buttons.
3. Turn on the printer.
4. Release the buttons when 'Performing Self Test' displays.
The message CONFIG MENU displays on top line of operator panel.
5. Scroll down and select 'Reset PC Cnt.'
Sep 25, 2008 | Lexmark Office Equipment & Supplies
Solution to epson c1100 error message
Turn printer off and remove photoconductor unit, close covers and turn printer back on without photoconductor, error will appear that you need to install photoconductor, install photoconductor and wait til it calibrates, if same error appears photoconductor is a consumable part you will have to replace it then.
Pls dnt 4get to rate solution. TY
Mar 18, 2008 | Epson Aculaser C1100 Printer
Here are the steps to reset the page count on a Lexmark E234, as described here:
  1. Power the printer on and get it to the Ready state.
  2. With the printer on and in the Ready state, open the front cover.
  3. Press and hold the Cancel button until all of the lights begin flashing up and down.
  4. Release the Cancel button and close the door. The photoconductor count should now be reset.
Hope that helps!
-MetaB
Aug 12, 2007 | Lexmark E238 Laser Printer
Dell 1710 Laser Printer Logo
306 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
