Question about Sony Televison & Video
Put in new replacement bulb,now have a band of red color at the top of my tv
    President:
  • Sony Master
  • 1,779 Answers
Make sure the lamp is properly seated in the cage and then seated in the set. There's a good chance the lamp is tipped in the cage.
Posted on Feb 01, 2010
What the voltage value of zener diodes? (D825, D826 red,red,gray) and D823 (red,yellow).
This table is the information used by MOST diode manufacturers that use color banding on diodes. Most manufacturers stamp the ID right on the diode but some do use color banding as the method of identification. For purposes of alignment, the side with any color band closest to either side of the diode is the equivalent of the left side of this table. The three examples in the table when associated with the values in the lower table, are identified as 1N64E for the top diode, 1N452G for the middle diode and 1N4762 for the bottom diode.
See the color coding
25789975-o5icj23xic0ud0c1fg3qznri-3-0.jpg http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Panasonic Televison & Video
Whire vertical band , 3 inches wide with red kine in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
Projector is showing a Red band on the top and Blue band on the bottom of the screen only really effects anything when that area is nomally white. Just started happening after I replaced the bulb. It
the problem is not caused by the lamp
check the LCD panels
check the input ports
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
http://www.lampdeng.com
Feb 27, 2014 | Office Equipment & Supplies
I have a toshiba 61h70. the tv had been shutting down after and few minutes and the red bulb was flashing also. I replaced the IC Chips and it resolved the flashing and shutting down issue. the green and...
You need to look with a meter at the resistors around the chips, they are usually gray in color with bands that denote value--a good guess is one or more were taken out by the chips--in these sets they will look fine---typical is 1.8 ohm (brown, gray, black bands).
At least one is open (bad--no reading across--like checking a fuse) and there will be several with identical color bands on them.
Let me know if I can help.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 16, 2010 | Toshiba 61H70 61" Rear Projection...
Red band at top of tv
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or that red band you are getting.May the Lord Jesus bless you!
Oct 20, 2009 | Sony Televison & Video
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Banding on screen
Since this TV is still new, it's much faster if you exchange the unit at the place of purchase and get a new one. You can also call Sony at 1-800-345-7669 (SONY) and get it service for free.
Jun 16, 2009 | Sony Televison & Video
Red band at the top of tv screen?
Your optical block is going bad. Contact sony support. They will sometimes warranty these even after the 1yr warrany has expired.
May 11, 2009 | Sony KDF-E502000 50" HDTV
Magnavox 50" DLP Tv power light comes on but then i hear a buzzing noise and then two red lights come on the tv. at no point does the picture turn on during this time. Can you please give me a possible...
Your bulb is burned out. I have had the same problem. It seems this television has an overheating problem--and short bulb life. I have had our 50 Magnavox dlp for two years and just put in the second bulb before Christmas. You can buy the bulb from a dealer on ebay for $99 and install it yourself. I is not in the housing so you have to carefully take out 4 screws and replace the bulb without touching the face of the bulb. To buy the one from Magnavox with the housing is much more expensive. I think the first time my husband replaced the bulb it took about 45 minutes--this time it took about 20.
Dec 16, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Televison & Video Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
