Question about Sanyo DRW-500 DVD Recorder
Frequent disc error messages
My Sanyo DRW-500 DVD recorder is about 3 years old. I have been getting disc error messages when trying to record on a new disc. Sometimes if i mess with the door a little on the front, then i can get it to work. this issue is becoming more frequent. is there some way that i can fix this? thanks!
  • Dachsie Jan 18, 2009
    When trying to record something, I will often get a "disc error" message; then the unit becomes frozen and the only way to unfreeze it is to unplug the machine from the outlet.  I have thrown away as many DVDs as I have used, all because of this problem.
    Brigadier General:
  • 6,966 Answers
Based on your post/description, there is an alignment problem with your disc tray. The unit has to be opened up and checked for mechanical problems. It is possible that some foreign material is preventing full closure of the tray. It is also possible that lubrication in some areas have caked up and rather than provide ease of mechanical action actually prevents its.
Alternately, the laser lens/eye could also be dirty. This could be corrected with the use of a CD cleaner readily available from most computer/audio shops/stores.
Additionally, a can of compressed air can be of big help in cleaning dust and small particles from the crannies and nooks of the mechanism/assembly.
If your concern has not been corrected after completion of the above procedures, you may need to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
Sanyo drw-500 dvd recorder will not recognize channels from antenna in setup
Have you set the Sanyo to "antenna" or to "cable" ?
If you've tried one setting, try the other.
Apr 16, 2014 | Sanyo DRW-500 DVD Recorder
Record mode doesn't work. Information is disrupted. play back is fine have not tried to fix
It could have some garbage, in the processor do to a small power surge, and if you leave it unplug for 40Min., from the wall, it should reset back to normal.
Feb 21, 2011 | Sanyo DRW-500 DVD Recorder
I record a program, I can play it & see it on the same recorder, but, If I play the DVD on any other DVD Player, an error message says " Improper Disc" or it won't read the DVD. What...
After you finish recording you have to finalize the disc before you can play it in another DVD player.The owners manual will have a section to tell you how to finalize the disc. WARNING!!! Once you have finalized the disc you will no longer be able to record on it. If this helps please rank me and leave a comment. I do not get paid in any way but I like doing this and want to make sure I am helping. I am adding a link where you can download the manual in case you lost it.
http://www.instructionsmanuals.com/modelo-2819-en-DVD+recorders.htm
Dec 18, 2010 | Sanyo DRW-1000 DVD Recorder/VCR
I recieve the error message no disc
Try getting a cleaner disc and clean the laser pickup. If this doesn't do it the pickup is bad and would not be feasible to repair as the pickups cost as much as the whole unit. Thanks
Nov 04, 2009 | Sanyo DRW-500 DVD Recorder
Sanyo DRW-500 Home DVd Player/Recorder
my drw-500 wont read any disc why its say NO DISC please help
Jul 23, 2008 | Sanyo DRW-500 DVD Recorder
Sanyo DVD recorder DVR-DX600
I don't know about where you guys are but when I went on to www.sanyo.co.nz and went into support and insturction manual searched DVD recorder it came up with english manuals for all their DVD recorders, just cick on the one you need
Jun 09, 2008 | Sanyo DRW-500 DVD Recorder
Sanyo drw-500
try cleaning the lens of your dvd if that does not work have a tech look at your dvd it could be having a problem in the recording circuit which is controlled by a chip.good luck
Jan 06, 2008 | Sanyo DRW-500 DVD Recorder
Sanyo DRW 500 DVD RECORDER
check partstore.com for a manual on your dvd recorder.good luck
Sep 08, 2007 | Sanyo DRW-500 DVD Recorder
Sanyo DRW-500 DVD Recorder Logo
113 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
