Question about Kidde Home Security
My kidde-copp-3 nighthawk is making a series of beeping noises every 10-15 secs. I don't have the user guide. can you help?
  • 476 Answers
When the AC power is diconnected and power is restored the system will chirp every 15 seconds with a lb(low battery) or CO reading. If the battery is low it will not stop chirping untill it detects a good battery(life of a batt is normally 1 year) press the test button to reset. The manufacturer recommends replacing the battery every 6 months. try the following link to obtain an owners manual: http://portal.knowledgebase.net/al/15121/16372/article.asp?aid=295593&tab=browse&bt=4&r=0.4353467
Posted on Feb 02, 2010
I find it interesting that the help line is only available Monday to Friday.I had called 1-800-880-6788 but to no avail. I will have to remind my unit in the future to only have problems during the week....
Everyone seems to be having problems with this Kidde Night Hawk Combo. Must be the nature of the beast. I think that once they came up with a combo unit, rather than two separate units, it was their downfall. But, that's just my professional opinion. Enough of that. Now to answer your question.
According to Kidde, if you received that E02 code, you should return it to them for repair or replacement. But, don't try to do it without a Return Merchandise Authorization. Unfortunately, you'll have to keep calling Monday - Friday. Remember, the are hundreds of other customers calling, too. Try to be patient.
Feb 05, 2011 | Kidde Nighthawk Combo Gas/co Detector
My Kidde "Nighthawk" carbon monoxide
Sounds like you may be due a warranty replacement. Call the Kidde "Hotline" at 1-800-880-6788 with your Model number, serial number, and manufacturing date. The original sales receipt would be helpful but probably not absolutely necessary. Good luck. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
Dec 23, 2010 | Kidde Nighthawk Combo Gas/co Detector
Kidde nighthawk carbon monoxide detector started beeping every 30 sec.pressed reset button on front beeping continued louder, put unit ouside in fresh air for few secs beeping stopped. I opened the...
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Crystal Robinson
PR Coordinator
Kidde
Dec 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model number KN-COPP-3 err beeping every 25-30 seconds, I replaced battery they still beep. They say to seek users guide, which can't be found. It seems to have started...
1. Change batteries.
2. Clean it.
3. Swap it with another location if you can.
If it still does not work properly consult the local fire dept. for free.
You may have to take it in repairs if all fails.
Nov 08, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
Model #KN-COPP-3.."Err" along w/occasional beeping. Tried to reset, but it continues to beeps. Other CO alarms in house show zero.
1) Does the display show "Err"? 2) When you press and hold the Peak Level button does the display change to "E09"? If so, then you have just been "had" by the grossly under-documented "planned obsolescence feature" called, rather matter-of-factly, "End of Life". This means that ~7 years after first being powered up, the unit will, BY DESIGN, cease to function, forcing you to buy a replacement. Would have been nice of them to include THAT warning on the OUTSIDE of the package. Call their "Hotline" at 1-800-880-6788 and tell them what you think of that policy.
Feb 15, 2010 | Kidde Nighthawk Combo Gas/co Detector
My Kidde Model # KN-COEG-3 keeps going off and lists 217 now 205 now again 217 and this is with the door open and fresh air coming into my place ??
I took the following from the Kidde website. They only answer the phone Mon-Fri, from 8-5, EST. I checked it out because my almost new Kidde CO detector is showing an Error code.
The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you.
Nov 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
Nov 24, 2008 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model kn-copp-b
Here is a link to the manual, or you can call the consumer hotline at 1-800-880-6788
Nov 10, 2008 | Kidde Nighthawk Combo Gas/co Detector
Kidde Carbon Monoxide Alarms
YES!!!! If this unit is working properly you should not be in the house. Maximum allowable safety level for an 8 hour period is 50! If you think it's working properly call the fire department! This will cause dizziness,nausea,etc. Let your fire department find the problem! If you don't believe me follow this link to owner's manual but do it quickly: http://www.kiddeus.com/utcfs/ws-384/Assets/KN-COB-B(9CO5)en.pdf
Feb 27, 2008 | Kidde Nighthawk Combo Gas/co Detector
Home Security Logo
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
