Question about Kenmore HE2 Plus Front Load Washer
When washer is in the spin cycle the machine starts to shake and walk across the floor.
    President:
  • 842 Answers
This will happen if the load is uneven and/or overweight. First thing to check is that you are not putting too much stuff in there. Remember, towels and the like are very absorbent, so the wet weight of them can sometimes be too much, they also tend to "clump" in one place, so mixing the textures of your load may help. Presuming that you are not doing anything that you have not done before and the problem has recently developed, another common issue you need to investigate is the load being too wet (and therefore too heavy) because its not getting drained properly in the drain cycle. The root of this can often be a simple blocked filter. Check and clean your filter, the problem may well go away.
Posted on Feb 02, 2010
vest6
  • 196 Answers
SOURCE: Washer walking across the floor in spin cylce
This machine uses an auto-adjust for the back portion and they tend to get stuck. Since it sits on a common chassis, insert two standard legs in the back. There are threaded holes that the legs go in. Rebalance the machine. Your problem should stop.
Posted on Jan 15, 2008
SOURCE: neptune washer walking across the floor
We have no complaints about the maytag neptune, except that it walks across the floor. My wife just called Maytag at 866-616-2601 , and was treated great, they are sending some parts to fix the problem, free of charge, and we are to get them installed free of charge when parts arrive. When you call that number, ask for someone who specializes in the vibration problems. Our maytag neptune is model # mah8700aww.
Posted on Feb 27, 2008
localwonder
  • 6784 Answers
SOURCE: washer tub vibration on spin cycle
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is istalled.
Posted on Jan 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: EXTREME SHAKING DURING SPIN CYCLE
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
caroldon
  • 17130 Answers
SOURCE: Machine shakes, rattles and "walks"
Possible that the drum is out of alignment, You will need to check the motor mountings, check to see if the suspension of the drum is good. if not remove and reset, check the counter weights and the shock absorbers.
Also check the drive shaft and the agitator assembly. finally the footings to be firm, use a water level to set.
Posted on May 16, 2011
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
Washer shakes and walks across the floor on spin washer is level and the brakes apear fine
Problem may be you may given less load to the machine if not means the spring tensions will be less in the top please kindly replace the springs
Dec 30, 2009 | Maytag SAV5910 Top Load Washer
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
