Question about RCA L32HD31 32 in. LCD HDTV
I was trying to wall mount a 32-inch flat screen. I broke the female threaded screw acceptor on 1 of the 4 holes. Now I cannot secure the brackets to the rear of the tv. It is not sturdy enough with only 3 screws attaching the brackets. Can this be fixed?
  • murraykimbal Feb 02, 2010
    No, it is a piece that broke out of the back of the tv. It is a metal female threaded adapter that you screw the brackets onto the tv, then you would attach the brackets to the wall mount bracket.
  • Anonymous Mar 24, 2014
    I NEED TO KNOW WHICH DIRECTION TO FACE THE WALL MOUNT I KINDA JUST NEED A PICTURE . THIS IS JUST A SIMPLE WALL MOUNT THAT CAME WITH THE TV . THERE IS 3 MAIN PIECES THEN THE 2 RODS. I KNOW THE FAT PIECE GOES ON THE WALL BUT DO I ONLY USE 1 SCREW TO SCREW MOUNT TO WALL, BECAUSE THERE IS ONLY ONE HOLE?
  • 102 Answers
If you get a slightly larger drill threader bit you may be able to rethread the hole to a slightly larger diameter.
Posted on Feb 01, 2010
  • Asb237 Feb 02, 2010
    o right, sorry i misread it. I don't think you would be able to order a replacement adapter from the manufacturer but it's probobly worth a try
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
How install this tv on a wall
Most flat screens mount using a universal mounting bracket. These are available at most stores that sell flat screens. There should be four treaded holes on the back of your set to allow it to be mounted to the bracket. these probably take an M4 (metric) screw. this information should be in your owners manual.
Sep 18, 2013 | Samsung LW32A33W 32 in. HD-Ready LCD...
I need the stand for a 32" insignia flat screen
You can buy an assortment of universal support bracket or universal stands at stores like walmart, Best Buy etc.... Check the back of your insignia and you will see the threaded holes made for this kind of bracket. I bought a 42 inch flat screen and bought a combination table/mounting bracket. It's great. Make sure you get a bracket that matches or exceeds the weight of the TV though. Good luck and feed back if u can.
Apr 18, 2013 | Insignia IS-LCDTV32 32 in. Television
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
I need to know the size of screws i neddto wall mount my tv
First you need a tv wall bracket made for that tv's weight and size to have a safe tv on your wall. The tv must be secured properly or it might fall. So the screws would come with this mounting kit and if they didn't I would fined out were they are. You must mount to a strong structure, like a stud in the wall or a metal frame built for it. The screws that I would use if might mounting kit did not have them would be as big as they would fit in the mounting bracket holes and that all the mounting holes wear being used and long enough to not be pulled out and in the stud about 3/4 of the way through the stud. They would be a good metal screw with a washer and the right threads for what ever material you are mounting it to. Thanks
Oct 05, 2010 | Televison & Video
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
RCA L32HD31 32 in. LCD HDTV Logo
366 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
