SOURCE: I Buy the Vtech V.Smile
Make sure the power cord is plugged in and that the red/white/yellow cables are plugged properly into the TV. Also, as you plug the red/white/yellow cables into the TV, make sure you turn the TV to the right channel - it is different for every TV. For instance, the red/white/yellow on the front of my Sony is labelled Video 2 - yours might be labelled FRONT, AUX, or something else.
Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
SOURCE: I have the Vtech, Laptop, # 53-00682-638. We have
You should be able to.Go to Vtech
and do a search.you should be able to com up with a pdf manual.
SOURCE: vtech whiz kid learning system has no sound. can
My son has a year old Vtech laptop and I can no longer get sound from it. Have replaced batteries but that has not solved the problem. Can anyone help?
