Question about Sony PlayStation® 3 (60 GB) Console
How to fix a ps3 after the power went off and the
I turned on my ps3 then there was a power outage for like a second then i truned it on again another outage for a sec then finally when i tried turning it on it wont turn on and i dont see any lights not even the red light on the ps3 what could i do to fix this please help
    Guru:
  • 111 Answers
It needs a new power supply. When the power came back on, most likely a surge damaged the power supply.
I buy mine at http://parts.consolerepairguy.com they run about $35 each.
I run a repair business and that place has best prices aside from Hong Kong which I don't trust.
Posted on Feb 02, 2010
Testimonial: "thank u"
I was playing my ps3 and the game froze and the picture went funny like all differnt colours.turned of then on again and its just a blank screen.how do i sort this problem out
holding the power button for few seconds will reset the ps3 to factory defaults , may be that should help you getting it working again :)
Jan 25, 2013 | Sony Playstation 3 (PS3) Console
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    I have a ps3 2 days ago we had a power outage and I tried to use it today and it only turns on for about 1 second then shuts off again I cannot get the disk out anymore can you help pleeeeze
    If you had a power outage then more than likely the power supply was damaged. You'll need to take the PS3 apart and swap out the old one with a new one.
    Nov 13, 2010 | Sony Playstation 3 (PS3) Console
    Had the ps3 working fine, plugged it into another tv and nothing, the tv wont pick up the signal.. went to plug it back into the 1st tv and still nothing
    Try resetting the display back to standard definition -
    Turn the PS3 off into standby (red light on)
    Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
    Wait for the PS3 display to reset
    Hope this helps
    Oct 26, 2010 | Sony Playstation 3 (PS3) Console
    After a power outage computer will not turn on
    first of all what kind of computer is i mean brand? secondly sounds like the power supply went bad..
    Jun 12, 2010 | Computers & Internet
    Ps3 power wont stay on
    search yellow light of death on google
    1)Turn off your playstation. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
    2) Check if there's any loose cable.
    3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
    If this did not work send to sony to get fixed
    May 09, 2010 | Sony Playstation 3 (PS3) Console
    No picture
    The first thing you have to do is that to make a video reset. The procedure to make a video reset is while the PS3 is off (red solid light) hold down the power button until you hear the SECOND beep, quickly release the power button..
    Your problem will be fixed.
    Apr 04, 2010 | Sony Playstation 3 (PS3) Console
    My ps3 switched off by its self recently and when i tried to switch it back on the power light was flashing red i pressed it once and it turned solid red then pressed it again it went green for around a...
    Yes this is the YLOD (Yellow light of death) to fix it you need to stop the heat build up getting to the main chips in the motherboard to do this you should use the recommended PS3 Repair guide.
    It is created by the same person as the top selling Xbox guide>>
    PS3 Repair Guide
    Nov 24, 2009 | Sony Playstation 3 (PS3) Console
    Power went out and back on; now printer won't print
    I had the same problem after a resent power outage. Here's what fixed mine.
    Turn the power switch off.
    Wait a 15-20 seconds
    While holding the button on the front panel down turn the power switch on.
    After the drum light comes on release the button wait then press the button again.
    Turn the machine off then back on again and you should be back in business.
    To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
    Oct 14, 2008 | Brother HL 1440 Laser Printer
    Sony PlayStation® 3 (60 GB) Console Logo
    222 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
