Connecting ipod touch to sony bravia tv through component - no picture, only sound. I vave got colours matched up right! Apple website seem to suggest this cable should work. Could it be something to do with the 1080P? I have itouch late 2009 model and the 3.1 software. Cable is MB128ZA/B
  • 8 more comments
  • M Fox Feb 02, 2010
    Hello and thanks for your post! Would you be able to give me an idea of where to check the scan setting please? It's a kdl-37s5500 I think! It's HD ready 1080p and the HD works fine with my 1080 blu Ray and with my 720 laptop but they are both connected by hdmi
    Hi again, it's set to pal. I thought that was correct for the uk? I've changed it to ntsc but it made no difference. BluRay plays through a different cable. The itouch is hooked straight into the tv thru component. Have looked thru tv menus and can't see anything relating to scan? Is there anything else I can tell you to help?
    I've searched my tv specs online and it does say it's got progressive scanning. Whether that automaticor not I don't know. The tv is 720/1080. Do you think that would make a difference? As the iPod is only 480/576
    Definitely component, blue green and red, with red and White audio. The cable is mb128 za/b if you want to look on apple? I only have hdmi for blu ray. Will try and loan some component cables and try to hook up something else up to it. Will also try hooking the iPod up to a different tv. Thanks for your help so far xx
  • M Fox Feb 03, 2010
    Thank you so much for finding the manual.
    I noticed on the apple website that some said it didnt work and other said it did. As I understand it, the new firmware simply blocks non-apple cables from being used? Did you think this too?
    If you mean do I switch the TV channel to the channel that is tuned to Component, yes I do.. and then I can hear sound, but not see the picture.
    Yes, thats why I went for component. Ive had composite before I wasnt impressed. I heard component was superior to composite. Maybe not though, Huh?!
    I will try my cable on my sisters Iphone when I next see her. See if it connects her device to her TV.
    Then I will try routing my ipod with her cables to her tv
    then try routing my ipod with my cables to her tv..
    just to try and decipher if its the cables or phone, and then I will take it to the apple shop, if all else fails. I phoned apple but they werent very helpful!
    Thanks for all your help. Youve been great!
    Oh ok, I see!! Yeah I did all that, as my sister said she has that problem with her composite laeds for her iphone! Will have another go tho. xx
    Hmmmm, just tried my daughter's 4th Gen Ipod with the same cable. Switched the TV OUT to ON, and tried to play movie.. its said to connect the TV out accessory, so I plugged in the cable... nothing happened!
    (Totally forgot my daughter had movie capability, earlier!)
    Buggar! The blu ray only has a HDMI cable with it.. and the PS2 uses composite. I dont own component cables :( Think Mum has some. Going on saturday so will pick them up from her and give that a go. WIll let you know, Take care til then xx
  • 201 Answers
Your TV needs to support "progressive scan" input ... may not work with a standard definition TV, if that's what you have. If you have an HD TV, make sure that if it has a setting for progressive scan, it's turned on.
Posted on Feb 02, 2010
  • 4 more comments
  • dc2772 Feb 02, 2010
    If your BluRay player is set to output progressive scan, your iPod should work too.
    On your iPod, go to the Video settings and make sure your "TV Signal" is set properly (NTSC). Also, make sure you have the latest firmware.
    You're sure you have your iPod Touch cable plugged into the component inputs of your TV, and not the composite inputs, right?
    If so, do you have a component cable for your BluRay player, and if so, does your BluRay player work when connected to the component inputs that you were using with your iPod Touch?
  • dc2772 Feb 03, 2010
    I did look up your cable on the Apple website. There was some confusion as to whether or not it works with the 3.1.2 firmware, but the consensus seems to be that it does.
    Here is the manual for your TV:
    http://pdf.crse.com/manuals/4141451112.p...
    The specifications section indicates that it supports 480p and 576p as well.
    Are you selecting actually selecting "component" as the signal source (page 17)? It doesn't get selected automatically.
    You know, I had a composite cable once, and I found it was "finicky" ... I'd have to go through a series of cable disconnects/connects, and rebooting the iPod, to get it to work. You might want to try that ... otherwise, I'm afraid I've run out of advice. :-(
    The component signal is definitely superior to a composite signal, when it works. ;-) My point is that you may want to try rebooting your iPod while it's connected to your TV, and/or disconnect and reconnect the cable from the iPod, in various sequences and see if that works. The iPod may need to be "triggered" to recognize that there's a cable there, and send the signal through it. Though if you say you are getting the audio signal, there's probably some other problem.
    So the problem is either the cable, or some setting on the TV. You could possibly eliminate the cable as the problem if you connect your BluRay player to the component inputs.
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
I've got a i-pod touch, how do I show that on my t.v.
If you want to output what's on your iPod Touch screen to your TV screen then you'll most likely be needing some kind of AV output cable to take the output from the iPod and put it on the TV. Consult an Apple store near you or the Apple website for the different cables available. The cable you choose will depend on what generation of iPod Touch you have and what kind of inputs your TV has, e.g. HDMI or Component.
Mar 27, 2014 | Computers & Internet
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have purchased the apple component tv cable for my ipod 5th generation but when playing back videos I have only sound - no picture. I have set the Ipod to tv out, PAL (Aust) & connected all the...
Hi, this seems to be a physical failure with your connections and not your TV input configuration (as you're able to listen to your audio). First, try to see if there's an obstruction on your iPod dock (maybe some dirt or dust) and on your AV cable. As the video travels through different pins than the USB or power, you may've not noticed the failure until now. Sony Bravia TVs are all built in the same factory, so they can easily change from NTSC and PAL, try going to your settings and change the TV out to NTSC. If everything else fails, take it to your Apple Store, they'll be more than happy to test it for you and if it's broken, replace it for a working one.
--Dennis
Feb 27, 2011 | Apple COMPONENT AV CABLE (MB128LL/A)
Sony KV-32FS12 Component Video 4 Has A Wavy Picture
sounds to me like the differnence between watchiing in progressive and interlace. these older tube tv's are not capable of displaying a progressive scanned image. like the first dvd players. check your video out settings on your ipod to make sure its an interlace output.
Apr 23, 2009 | Sony KV-32FS12 32" TV
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Mar 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Connecting Vostro 1400 to Sony Bravia BR6?
To properly drive your TV set, your computer will have to be able to supply 1366 x 768 with a 60 Hz refresh rate.
A resolution of 1280 X 800 is high. LCD and Plasma sets are very critical for the maximum resolution. You can go lower but not higher. If a lower than native resolution is used there may be some aspect ratio distortion, and the picture quality will be degraded.
There is a spec list at the link below:
bravia-kdl-v40xbr1/4507-6482_7-31470102.html?tag=mncol;psum">http://reviews.cnet.com/flat-panel-tvs/sony-bravia-kdl-v40xbr1/4507-6482_7-31470102.html?tag=mncol;psum
Jerry G.
Jan 29, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to connect Apple iPOD to Sony Bravia LCD
http://www.applesource.com.au/ipod/soa/Play-back-iPod-videos-on-your-TV/0,2000070791,339287576,00.htm
Connect your iPod to your TV with a DIY cable
The iPod A/V Cable is stylish and handy, but you may feel it's not worth the money; the Belkin cable gives you twice the value per foot but costs the same overall. For a less expensive alternative, find a standard A/V cable with three RCA plugs at one end (coded red, white, and yellow) and a 1/8-inch A/V plug with three bands at the other end.
To set up your iPod for playback, plug the 1/8-inch connector into your iPod's headphone port, and then plug the yellow, white, and red RCA connectors into the RCA jacks on your TV in this non-color-coded way:
Jan 19, 2009 | Durabrand DU1301 TV
Sound ok no picture
If it is connected to a cable box with an HDMI cable, try connecting up component instead
Oct 13, 2008 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
2,858 people viewed this question
 Grubhead
Grubhead
