Question about Music
Korg pa-50 no sound from right speaker but has sound from left
Korg pa-50 no sound from right speaker while playing but has sound in both speaker when i conncet my mp3 and play song from mp3 means speakers are fine, software is updated to latest,no other problems or key issues, this is the only problem, what part is causing the problem? please help
  • london_22_ma Feb 02, 2010
    hey, tnx for the respond, when i conncet audio input such as mp3 the speaker dont get effected by it, the left make sound and the right make no sound when playing from keyboard no matter if i connect anything or not, the both speaker has sound of mp3 music from them and the keyboard while playing note only comes from the left, and when the input is out its the same thing, i have updated the OS on system so that means it should reset the system and i dont think its the settings cuz the setting would be reset after updating OS, any suggestion? tnx
  • Music Master
  • 5,603 Answers
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Posted on Feb 01, 2010
  • Fred Yearian Feb 02, 2010
    OK... I downloaded the user manual and on the first page it says:
    "When turning the instrument on, please be assured the BALANCE slider is set to
    the center. This sets both Sequencer 1 (SEQ1) and Sequencer 2 (SEQ2) to their
    maximum level. This will avoid you start a Song without hearing anything."
    Next, on page 43 they talk about the mixer pans... MAKE sure the REALTIME (keyboard) pan is set to center.
    Also read about Pan modulation on page 117. If this parameter were set to one end of the keyboard, that could cause the problem.
Problem with Korg PA-50 joystick in Program mode
Most likely the Program Mode does not copy joystick info.
Get the User Manual online, if you want Google
KORG PA50 FACTORY RESET
But then you will lose all your memories...
Dec 02, 2017 | Korg Music
GM VOICE NOT PLAYING
Your best bet is to contact Korg. Here is their link-
http://www.korg.com/us/support/contact
Jan 01, 2016 | Korg X50 X-50 Keyboard
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
May 01, 2015 | Korg M50 61-Key Music Workstation Keyboard...
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
FACTORY RESET ON KORG pa50SD
i use korgpa50sd i had some voices by default but once when i inserted my sd card into the arranger every voices got deleted and now everything is new...so can you please help me to get back the old voices?
Apr 02, 2012 | Korg Pa50 Professional Arranger Keyboard...
Hi i have problems with my speakers on my pa 800 ,when i just play tones its clear but when i play the rhytms doesn't play right is not clear
Read your user manual about keyboard split. OFTEN the rhythms use the keys below F sharp for the chording of rhythm. When in this mode, you should restrict your melody to notes above F sharp that is to the left of middle C. If you play melody below this it will confuse the rhythm chording. You can likely change the split point of the keyboard, however, the F sharp split is the standard and I would suggest staying with it.
Dec 14, 2011 | Korg Pa800 Synthesizer
Sp250 right outout seems to have broken and as a result there is no sound coming from the speakers on the keyboard or through the PA. If we use the left output through the PA - it works, Could you advise...
Check if headphone jack also has right channel dead... If headphones work on both channels, switch contacts on headphone jack MIGHT be the problem.
Jan 17, 2011 | Korg SP-250
KORG PA 800
Many of these pedal have more than switches. Some use resistors as part of a matrix. The chances of success are only 50-50 unless you rewire the FC01 to be exactly the same as the EC5.
May 15, 2010 | Korg Pa800 Synthesizer
Music Logo
660 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
