Question about ATI RADEON X1300 PRO, (256 MB) AGP Graphic Card
I have dual monitors both are connected but one can not be seen
    Problem Solver:
  • 9 Answers
Rightclick on your desktop, select properties, go to the most right tab.. there you see the second monitor in grey, select it. you can activate it there.
Posted on Feb 02, 2010
Install both computers withdual monitors
Ok, so the idea of this KVM is to allow two computers which are dual monitor enabled to share one set of dual monitors. This means that PC1 can output to two monitors at once and PC2 can output to two monitors at once, however you only have two monitors.
You should take two cables and plug in both to the dual display output on PC1 (if supported) and then plug them into 'A/B' Computer 1, you should then take two cables and plug them into the dual display output on PC2 (if supported) and plug them into 'A/B' Computer 2.
Now take two cables and plug one into Monitor A and connect this to one of your screens and plug one into Monitor B and plug this into your other screen.
You should see this in the diagram here: http://www.linkskey.com/detail.php?Productid=165
Only one PC can be used at a time.
To support this the back of EACH PC should have a graphics card with two VGA output connections like this:
http://forums.radioreference.com/attachments/computer/25337d1254007019-running-dual-monitors-vdmt090-wb.jpg
Nov 11, 2013 | Linkskey (lkv-dm02sk)
Connecting 2 monitors to laptop without dock
I highly doubt that your machine will allow more than one monitor without both of the monitors being the same image. External monitors on laptops can be used to extend the display, but only by using the laptop screen as one of the two. It is possible to split VGA to duplicate images on two screens, but true dual monitors will require a DMS output or something similar, which I've never seen on a laptop.
Nov 17, 2012 | HP L1910 Monitor
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
My monitors go black
Make sure you download the latest drivers.
http://support.amd.com/us/gpudownload/Pages/index.aspx
have you ever seen the card work before. If not then its probably dead. I would contact whomever you bought it from asap.
Apr 05, 2010 | ATI ALL-IN-WONDER 9000 PRO (64 MB) Graphic...
INstalled video card to D945 Intel board, and now the onboard video does not work. I wish to run 2 monitors with same input.
Unfortunately most basic motherboard chipsets do not support multiple monitor setups.
They are designed to become inactive when you connect a slot based video card.
to use 2 monitors you would need to connect them both to the card in the slot if it supports dual monitors.
Mar 03, 2010 | Computers & Internet
I wanted to connect another monitor to laptop so i can have dual monitors. My laptop does not have the place to put the monitor cord thingy .. what can i do?
well, you need a video card that can support a dual monitor setup. As far as a laptop I personally haven't seen this setup but if it is possible then thats how you're going to accomplish it. You'll find them with multi port setups on the back of the card itself. Also you need to make sure your case will support the addition. If not you can make the hole yourself or attempt to purchase a new case with the holes required. I've only done/seen this done on PC's but that should translate the same
Feb 06, 2010 | Dell Computers & Internet
I have dual monitors. One now has different
Hi
check by connecting the VGA Cable of the faulty Monitor directly to the CPU means Tower connection ..
if the screen is still blue green then there is something wrong with the cable VGA Cable
Jan 22, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Kenwood ddx8017 stereo
NEED MORE INFO DO YOU HAVE AN IPOD CABLE ATTACHED OR A SATELLITE RADIO ATTACHED HAVE SEEN THIS PROBLEM WHEN CABLES FOR THESE OTHER COMPONENTS ARE THERE BUT NOT THE DEVICE ITSELF. LET ME KNOW WHAT ALL IS ATTACHED.
Mar 07, 2008 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Dual monitors
You'll need a dual-monitor video card in your computer. The GVLM1928 is basically two monitors on a shared stand. Each side of the monitor has a separate video connection.
Feb 26, 2008 | Computers & Internet
ATI RADEON X1300 PRO, (256 MB) AGP Graphic Card Logo
199 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
