Question about Canon DW 100 DVD-RW Burner
Cannon DVD Burner DW100
Recorded on Cannon FH200 dvd camcorder. Cannot transfer to Cannon AVCHD. receive message operation cancelled. Not reading disk. Any suggestions why? Recorded in MP format (higher quality video).
I had this problem also when trying to connect to my HF200. I found a solution. The DVD recorder does not like MXP recordings, in fact it hates them. You will have to make sure no MXP recordings are present on your SD card/Hard drive. Then any recordings you make with the intension of recording to DVD need to be made in FXP mode or below. But remember if you have a selection of recordings on your SD/HD and just one is in MXP mode, you will get the error 'Operation cancelled'. Just as a sidenote, I phoned canon support about this problem, they were useless, promised me a callback that I never got!
Posted on Mar 18, 2010
  • rhaci Oct 07, 2010
    ptbeebe, you mentioned recording in FXP mode or below, I recorded in LP mode and still can not get a dvd from the DW 100 to play, even on my new BluRay player. Must I set the camcorder to FXP mode before shooting???
    If you are still around out there reply to rhaci@charter.net thanks Ron Harke St. Louis MO
I have bought a cannon XH-A1 HDV camera but find i cannot capture scenes using Pinnacle Studio plus v9 could you please advise me on what is required, may be studio 11 plus for windows XP will solve this?
Hi there
Pinnacle Studio Plus V.9 can only be used for editing DV and not HDV however Pinnacle Studio Plus V.11 can be used to edit both DV and HDV.
Please remember to put a good rating on this post.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Cameras
Tip
How to burn AVCHD Lite to DVD on Mac OS X?
AVCHD-Lite, which is a subset of the AVCHD format popularized by hard disk camcorders from Sony, Panasonic, and Canon, uses h.264 video coupled with AAC audio for recording movies. AVCHD Lite video is currently used by Panasonic DMC-ZS3, Panasonic DMC-FZ3, Sony, Cannon AVCHD Lite Camcorder, etc.
26b78f7afa860b1f_2_197_.jpg The main differences between AVCHD Lite and the regular AVCHD: a maximum resolution of 1280 x 720p in AVCHD Lite compared to 1920 x 1080p in regular AVCHD and a less-intensive compression method - both of which make the format more suitable for less powerful camera hardware.
What you need to burn AVCHD Lite to DVD on Mac OS X?
Neither of AVCHD and AVCHD Lite video is directly supported by iMovie or iDVD on Mac OS(10.6.3 Snow Leopard included) if you want to burn AVCHD Lite to DVD. There are 3rd-party solutions that work with varying degrees of success in allowing you to work with AVCHD Lite video on Mac, like Daniusoft DVD Creator for Mac . It is DVD Burner that can convert AVCHD Lite video to DVD. With it, you can add DVD menu, edit videos and pictures, add transitions and effect, etc.
Below is the step by step guide on how to burn AVCHD to DVD on Mac OS X
Step 1. Load files Just click “+” button to import AVCHD Lite files to this program or simply drag and drop them to it. And rearrange the file list by using the up-down arrows.
Tips: You can freely drag and drop the thumbnail to merge or split the video files.
Step 2. Edit files (Optional) To personalize your DVD files, you can edit the video files by clicking “Edit” button. For video files, you can crop the frame size, trim into several clips, append effects, add picture/text watermark and rotate.
Step 3. Create DVD Menu (Optional) This Mac DVD Creator also allows you to create your own DVD menu with rich selections of DVD menu template. Simply click “Menu” button to select one and set the “Frame”, “Button” and “Text” to customize your DVD menu.
Step 4. Start to burn After all necessary settings, you need to insert a blank or rewritable disc to your Mac if you want to burn video files on DVD disc. Or you can simply convert the videos to DVD folder, .dvdmedia or ISO file on your Mac for later burning.
That is it! Within several clicks, you can burn AVCHD lite to DVD easily. So, why not download Daniusoft DVD Creator for Mac for a try?
on May 21, 2010 | Computers & Internet
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
Transfer footage from DVD to Computer for editing
I use ISO Buster to read the AVCHD footage into my computer and then edit with Pinnacle Studio. With ISO Buster, you place the 3" AVCHD DVD into your regular DVD Rom drive on your computer and it will rip the raw files directly from the disk. You cannot transfer the movies from the DX1 to Pinnacle or any other editor using the USB cable.
Mar 18, 2008 | Panasonic HDC-DX1 DVD Camcorder
No sound records on dvd
http://sony.storagesupport.com/dvdrw/vrdmc5dwn.htm
System Software Upgrade
Version: 30R2
Release Date: 01/06/08
New Features:
  • Allows VRD-MC5 to support Sony's 1920 x 1080 AVCHD Handycam.
  • Allows VRD-MC5 to record video directly from a MemoryStick memory card recorded using a Sony's MemoryStick Handycam camcorder.
Improvements:
  • Fixes problems with no audio during playback on certain camcorders recorded through 1394 or i-link connection.
  • Corrects signal detections with some camcorders as copy-protected.
Instructions | Download Updater (4 MB)
Dec 30, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Will not read disk recorded on Samsung DVD digital Camcorder
The disk needs finalizing.
However this then will make the disk unusable for anything else
Switch to CR R or DVD R as appropriate
Dec 18, 2007 | Plextor PX-740A (00765075107763) DVD RW...
Open Questions:
Canon DW 100 DVD-RW Burner Logo
621 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
