Question about Tomtom ONE GPS Receiver
Failure to obtain satalites on unit, tomtomone
Have not been able to obtain a connection with the satalites. Unit will not work out of the box.
  • flowerpet Feb 22, 2008
    Went to tomtom.com and downloaded information needed. Unit now works. Thanks for your interest.
  • Kevin Miller May 11, 2010
    What happens when you turn the unit on?
  • 504 Answers
No problem. Anything I can do in the future, let me know.
Posted on Feb 23, 2008
Sony KDS 55A2000 Unit has no Blue hue... only green and red. checked the inputs and sat box (sub'd) all the inputs are correct. can not adjust the hue to recover green. bulb is fairly new. ...
Unplug,replug tv and satalite box both an hour later.The tv,will reset itself,back to factory.Satalite box should upgrade it softwares.Tv now should have all it colors back.Not,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 14, 2010 | Sony KDS55A2000 55" HDTV
I have a Garmin 3600. When I want to use the GPS feature, and I open the antenna, all I get is Acquiring Satellites, but nothing happens (the little indicatior on the bottom shows activity). I thinkthere...
If you can obtain an external antenna from another IQ3600 user it
will plug into the connecter on the top of the unit and bypass the fold out antenna. I had to buy one because the windshield in my Pont Montanna would block the satalite signals. When I plug in the external antenna I do not have to fold out the antenna on the unit.
That will check to see if the unit is recieving and /or if the fold out
wire is broken. The external antenna is not Garmin specific but the
plug on the end is so another gps antenna with the same end plug works.
Aug 16, 2010 | Garmin iQue 3600 GPS Receiver
Tomtomone stuck with frozen screen and wont switch off can switch off using the reset button but when switched back it sticks on the tomtomone screen
Your TomTom home software is corrupted:
1) Try a 'hard reset': while the power is on, stick a small (tooth/match) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressure on the stick will cause a complete system reboot if possible.
2) Check the health of your Tomtom One flash drive: connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem.
3) Restore software: using TomTom Home, restore from a previous backup followed by a device update while connected online.
Hope it helps: let me know how you go and good luck!
Jan 06, 2010 | Tomtom ONE GPS Receiver
Tomtom one xl,first time user,turn on power,what next
hi,
just click on this site and you will be directly connected to the guiders manual of your unit.
http://www.scribd.com/doc/249380/TomTomONE-Manual
thanks,
please don't forget to rate our answers properly.
Feb 19, 2009 | Tomtom One XL GPS Receiver
Direct satalite failure
If the tv works and its just the sattelite portion of the tv that doesn't work you can alway just use a new sattelite box and connect it to the tv via the rear inputs on the tv and then just select the coresponding input to view the sattelite chanels.
Dec 28, 2008 | RCA F38310 38" TV
Raymarine A-65 unable to find satalites
If you have a loose RS12 try moving it around the deck and see if it make a diffrence.There might be something knocking it out.
If it is doing a cold start it cold take up to 10 min to get a fix. Once it has a fix it will aquire the next time much quicker.RS12's are mostly rock solid and get great fixes.
Also set the time up on the A65 to what you are at ,IE, universal time minus 5 if you are on the east coast of the US.Time set up is under the units menu. Hope this helps
May 17, 2008 | Raymarine A65 Combo GPS...
My garmin c320 wont track any satalites
hi, my garmin c320 has a clear view of the sky but it cant track any satalites i don't know what to do. or if there is anything to do. can some please help me. thanks
Apr 29, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
I connected a different charging lead to my TomTomOne, not realising it had a higher power output. My TomTom died instantly. The green light on top of the unit comes on but nothing else. Any help greatly...
If you fed the unit with a charger with much to high voltage, you might have "fried" it. If so, not much to do than repair/throw in the bin...
Apr 16, 2008 | GPS
Connection
hi, you can now buy a box that can take upto 5 hdmi inputs to plug into your tv, i'm sure your local game shop will supplie them, if not search on ebay. hope this helps
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
Tomtom ONE GPS Receiver Logo
46 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
