Question about Microsoft Internet Explorer 8
Can't use photouploader. dep shuts me down when active x trys to load
Posted on Feb 02, 2010
Data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system settings.in upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services only.click on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
Oct 24, 2011 | HP Pavilion DV6000T 15.4­ NOTEBOOK LAPTOP...
DEP as IE shuts of
1. Start Control Panel System and Maintenance Performance Information and Tools Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.
Alternatively
A) In the command prompt, type bcdedit.exe /set {current} nx AlwaysOff and press Enter.
B) You should get a success message back
C) Close the command prompt.
D) Restart the computer to apply.
A) In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter.
Regards
Oct 24, 2011 | Microsoft Windows? Vista Home Premium...
Windows shuts down the suite reporting DEP to protect computer
You could try turning DEP off, by doing the following:
Right Click on My Computer (either on the desktop or start menu)
Click Properties
Select the Advanced Tab
Click on Performance Settings
Click on the Data Excution Prevention tab
Select 'Turn on DEP for esential Windows prorgrams and Services only'
Click OK on all the boxes, then try whatever you were doing again?
Mar 12, 2011 | Computers & Internet
When I try to play a big fish game I get the drm activator stopped working message...the game is midnight mysteries..curse of the raven or something like that..the solution involving checking windows to...
To fix this, go to: Control Panel > System > Advanced System Settings > Settings (under performance) > DEP (tab) and then add your program as an exception.
Aug 16, 2010 | Computers & Internet
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Data execution
DEP (data execution prevention) attempts to separate "data" (such as the text of a webpage) from "instructions" ("move the string 'abc' to locations '12345/12346/12347'"), to prevent computer-hackers from introducing "data" (downloaded from a maliciously-constructed web-page) into an area marked as "instructions". The "threat" here is that the "data" will actually be "instructions" of the hacker's choosing, thus giving the hacker a chance to run instructions to completely "take-over" control of your computer.
Click "Start"
Click "All Programs"
Click "Accessories"
Click "System Tools"
Click "Internet Explorer (no add-ons)"
Do some web-surfing.
Close Internet Explorer.
If it closes "normally", then one of the "add-ons" that usually is loaded when Internet Explorer starts is causing the DEP exception.
Start Internet Explorer.
Click Tools
Click Manage Add-ons.
Choose one "suspicious" add-on, and "disable" it.
Close I.E.
If it closes normally, then that add-on should _stay_ as "disabled".
Nov 19, 2009 | Microsoft Computers & Internet
Installing AVG 8.5 on Windows XP professional getting error 0xc0070002. What is the fix?
Your computer's processor blocked an activity of a program by stopping the computer from working to prevent the activity from being executed (also known as DEP or Data Execution Prevention) and giving such error instead.
Try turning off the DEP for all programs by:
- opening Start > Control Panel > System
- Click on 'Advanced' tab
- In the performance area, click 'Settings' button
- A new window will appear
- Click on 'Data Execution Prevention' tab
- Click on the upper radio button (run DEP only for Windows services)
- Restart your computer
If it doesn't work or is turned off for all programs already then there seems to be a problem with your Windows (since you said that IE takes 100% CPU process), or the antivirus program isn't really compatible with your hardware and/or driver software.
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
My computer shut down on its own and now it will not turn on
Hi, I think the BIOS on the mainboard does not work properly or may damaged, because you have not the first activity signs on your computer.
Aug 20, 2009 | HP Compaq Motherboard
Why do i keep getting DEP error message each time i close IE8 or a tab? when i close a tab ie8 reloads it because of dep problems can i go back t ie7 and will this stop the reloads i now have to go to...
You can disable DEP by following these steps:
Disable Data Execution Prevention (DEP) completely
  1. Click Start, and then click Control Panel.
  2. Under Pick a category, click Performance and Maintenance.
  3. Under or Pick a Control Panel icon, click System.
  4. Click the Advanced tab, and in the Startup and Recovery area, click Settings.
  5. In the SystemStartup area, click Edit.
  6. In Notepad, click Edit and then click Find.
  7. In the Find what field, type /noexecute and then click Find Next.
  8. In the Find dialog box click Cancel.
  9. Replace the policy_level (for example, "OptIn" default) with "AlwaysOff" (without the quotes).
    WARNING: Be sure to enter the text carefully. Your boot.ini file switch should now read:
    /noexecute=AlwaysOff
  10. In Notepad, click File and then click Save.
  11. Click OK to close Startup and Recovery.
  12. Click OK to close System Properties and then restart your computer.
This setting does not provide any DEP coverage for any part of the system, regardless of hardware DEP support.
Verifying DEP is Disabled
  4. Click the Advanced tab.
  5. In the Performance area, click Settings and then click Data Execution Prevention.
  6. Verify that the DEP settings are unavailable and then click OK to close Performance Settings.
  7. Click OK to close System Properties then close Performance and Maintenance.
Thank you!
Sabharish
Jun 03, 2009 | Microsoft Internet Explorer 8
Uploading picture albums on facebook or bebo
it might be a trojan on your computer use this online scanner
http://www.runscanner.net/filelibrary/photouploader.ocx.html
Oct 18, 2008 | Computers & Internet
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
