Question about Xerox Office Equipment & Supplies
I have a Xerox printer - model XC830. The machine turns on but all the function buttons are not working, like they are all frozen. Please help. Thank you.
  • mfros Feb 02, 2010
    Followed your suggestions. No paper jam, no bits or scrap of paper caught. Still not working. Any further suggestions? Thank you.
    President:
  • 4,070 Answers
Well, if its kinda stucked up try the maintenance check of your printer, or maybe you need to reset your printers firmware. thre are available online printer resetters just type the printer model. hope it works
Posted on Feb 03, 2010
    Brigadier General:
  • 3,917 Answers
Well the common reason for a frozen Xerox machine is paper jam or piece of paper caught somewhere. Unplug the power cord, look at all the rollers for paper scraps, clean, check the little tabs that check for paper bits. Make sure they are free to move and clear of paper scraps, make sure all covers are installed or closed accurately.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 01, 2010
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
My Xerox 8560 Phaser printer started doing a random test and after initializing, I received an error code of 09,038.46:10184. I searched online but couldn't find this error and what it meant. And I...
  • Turn off the printer. Turn on the printer.
  • As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
  • Release the buttons, it will now come up in the service mode.
  • Scroll down to the function menu, hit ok, scroll to clear isc fault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jul 18, 2011 | Office Equipment & Supplies
How to solved code H4 Xerox Xc1245
This code is akmost always a false code. I would try clearing it by entering the following key sequence:
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" (Note that the exposure mode key is the far left key and that these 4 keys must be pressed within 4 seconds)
The display should have gone blank if these 4 keys were pressed properly.
Now enter 14 as if you were making 14 copies then press the Print Button.
This should clear the H4 code and the machine should operate normally.
If not and the H4 comes back then you have either a thermal fuse or heater lamp failure.
Good Lucj
Nov 09, 2009 | Xerox XC356 Copier
Xerox XC830, flashing 'P'
I have used this tip numerous times with great success.
Remove the paper tray and take all the paper out of the tray. Now on the metal plate that springs up where the paper goes there are 2 fiber pads that are about an inch square. Spray these 2 pads with glass cleaner until they are wet. Wipe off the metal around the pads and re-install the paper tray with NO paper in the tray. Now tray and make a copy....you will of course get the "P" light. Just hit C to clear it and hit the print button again. Do this at least 4 or 5 times. What you are doing here is cleaning the feed rollers by having them turn against the pads with the cleaner on them. Next take out the tray, blot the pads somewhat dry and add paper to the tray, re-install the tray and try copying again.
Should feed paper now unless you have a mechanical issue.
Good Luck.
Oct 29, 2009 | Office Equipment & Supplies
My Xerox XC830 copies are dark and have lines but otherwise present the image. How can I make the background white again.? Thanks! Ron
You probably needs some servicing. Drum, developer and other parts have a life cycle and once it's exceeded you can start having copy quality issues. Unfortunately there is no easy fix.
Jul 03, 2009 | Xerox Office Equipment & Supplies
H-4 model xc830 copier
Performing a Fault Reset 14 will reset your copier and will help to clear error codes. 1. Turn the power off. 2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button. 3. Locate the Auto Button the lower left corner of the Control Panel. 4. Turn the power back on. 5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear. 6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5. 7. Program the copier as if you were going to make 14 copies. 8. Press the green [Start] button to store the reset code. The copier will return to the ready position. 9. Run a test copy.
Jun 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Phaser 8500DN printer error : 09,037.45:67244
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Mar 05, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
Xerox workcentre pro 635
http://download.support.xerox.com/pub/docs/WorkCentre_Pro_635/userdocs/any-os/en/WCP635-645-657_UG.zip
Aug 28, 2007 | Xerox WorkCentre Pro 635 Laser Printer
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
