Question about Toshiba DKT3210-S Corded Phone
HOW TO MUTE THE RING VOLUME FOR A INCOMING CALL?
  • 1,284 Answers
Hi, you can mute the volume for all incoming calls by following this instructions..
Press #9876 to enter user programming mode
Press hold
Press the flexible button to set or change
Enter 180 (the code for mute)
Press the same flexible button (flashing) to save the setting. DATA PROGRAMMED appears on the LCD
Posted on Feb 01, 2010
  • Shehu Pro
    Shehu Pro Feb 02, 2010
    To adjust Ring tone, Handsfree, Answerback and Speaker off-hook call announce, follow this instructions....
    Make sure the volume is idle and the handset is on-hook, press the VOLUME UP to increase volume and VOLUME DOWN to decrease volume. This adjusts volume for your telephone's ring tone, handsfree answerback and speaker offhook call announce simultaneously....
    Sorry for the initial erroneous message, this is the proper way as written in the manual...
    Take care
Our incoming calls are not ringing out loud on our NorStar M7310 - how do we correct?
Did you check for the volume control and its adjustments? Do you have the setting on "mute?"
Oct 13, 2015 | NorStar M7310 Corded Phone
How to volume the KX-T7730.. if they have incoming call... i see only the light of the button but no ring.. pls.. help me
The volume control only changes the volume of the handset, headset or speaker. The volume for the ringer is on the left side of the phone, there are three settings, mute medium and loud.
Jun 11, 2014 | Panasonic KX-T7730 Corded Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
My iphone will not ring when called. I have checked settings and all look good. I can hear my alerts, alarms and when testing ringtones (and volume is up). However, when I receive an incoming call, i...
try checking the mute button on top of the volume buttons. if you see an orange dot or line, it is on mute so slide it to hide the orange dot or line and the phone should be fine.
May 09, 2011 | Apple iPhone Smartphone
Incoming calls don't ring
your setting may be a "0" volume level rather than mute.
Try increasing the volume setting for the ringer
Sep 08, 2009 | Cell Phones
Setup
Yes, just set the receive mode to "manual" the machine will then just ring when a fax is incoming and not print. It may become annoying after a while because the sending machine will try to send numerous times. You can get around this by setting the ring volume to mute.
Jun 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Toshiba DKT3210-S Corded Phone Logo
145 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
