Question about Ricoh 4420NF Printer
I have a ricoh 4420NF. it USED to forward faxes
I have a ricoh 4420NF. it USED to forward faxes to my email in .pdf format. i made some changes, ONLY to the name of the printer (so i thought) but now, everything is normal except that it now forwards me faxed in .TIF format, which my users hate. i found a switch to change whether it SCANS to a .pdf for emailing me, but i cant find any LISTED switch setting that controls what format attachments are made in for incoming faxes. ive checked all through the paper users manual, and the downloaded manual from Ricoh... no luck... tell me what switch controls format of email forwarding for incoming faxes and ill go from there. thanks
jell587
  • 447 Answers
SOURCE: Ricoh fax 4420NF machine needs new toner.
Follow this link to download the service manual for your machine.
Posted on Feb 23, 2009
bdlimon
  • 19 Answers
SOURCE: New Laptop with Vista Scans Documents as .tif instead of .pdf Why
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf268
Posted on Sep 06, 2009
  • 240 Answers
SOURCE: Only scans in TIF form. Want scans in PDF form.
HP support has the following documentation: (Copy and paste the following link into the location bar of your browser)
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01487633
I hope this helps!
Posted on Dec 10, 2009
  • 903 Answers
SOURCE: trying to forward incoming faxes
The two most likely problems preventing you from forwarding your faxes are:
1. There is a problem with your DNS server translating the SMTP server name. Instead of typing in the server's name (smtp-server.rochester.rr.com) try typing in its IP address. If the problem lies with DNS, that should correct it.
2. The Linksys router may be blocking port 25. Go into the router's configuration settings and open an exception for port 25, or enable port forwarding for that specific port.
Did either of these steps solve your problem?
Posted on Feb 13, 2011
  • 254 Answers
SOURCE: HOW DO I SET UP A CONFORMATION PAGE FOR A RICOH 4420NF?
Got to the advanced features and check that the selected papersize is A4 and not US legal
Posted on Oct 21, 2011
Paper jam on exit sensor MP2000
change the exit sensor or contact one of technicians on
  • Auckland
    Level 2, 60 Stanley Street, Parnell
    P.O. Box 68-024, Newton
    Auckland 1010
    Phone 09 - 374 0701
    Fax 09 - 368 6001
    Email ricohnz@ricoh.co.nz
  • Wellington
    123 Taranaki Street
    P.O. Box 10-258
    Wellington 6011
    Phone 04 - 381 7600
    Fax 04 - 381 7615
    Email wellington@ricoh.co.nz
  • Hamilton
    Cnr Anglesea & London Streets
    P.O. Box 758, Waikato Mail Centre
    Hamilton 3204
    Phone 07 - 957 4500
    Fax 07 - 957 4519
    Email hamilton@ricoh.co.nz
  • pnorth@ricoh.co.nz
    • wellington@ricoh.co.nz
    • christchurch@ricoh.co.nz
    • dunedin@ricoh.co.nz
Mar 10, 2014 | Ricoh Aficio MP 2000 Black and White...
Scan to email
Have you inputted the smtp server address in the machine?
Oct 08, 2013 | Ricoh 4420NF Printer
Scan to email
more details please
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
I NEED AN ADVANCED FEATURES MANUAL FOR A RICOH 4420NF
tHE ADVANCED FEATURES MANUAL FOR 3045 FAX IS AVAILABLE FOR DOWN LOAD on the web, I'm sure that your functions are similar on your 4420. May be tey are not dispose in the same way but the logic is the same.
Oct 21, 2011 | Ricoh 4420NF Printer
Oct 20, 2011 | Ricoh 4420NF Printer
How do i ctrl-alt-del a Ricoh fax/laser printer - and wipe it all out inside to prepare to sell it to a new company?
Navigate through the on-screen menu items, and find the "reset to factory settings" option, and click it.
Jan 29, 2010 | Ricoh 4420NF Printer
Feb 23, 2009 | Ricoh 4420NF Printer
Ricoh 1170L model
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
This is the link for the manuals
Scroll down to Facsimile
From the Drop Down Menu, choose your machine and click GO
It will take you to the manual (PDF format)
I hope this will help you.
Mar 27, 2008 | Office Equipment & Supplies
Ricoh 4420NF Printer Logo
241 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
