Question about Panasonic KX-P7100 Laser Printer
Panasonis KX-P7305 leaking toner
Toner leaks to margin of printout Usually on duplex side
Have cleaned but not dismantled machine
  • Lionroy Feb 19, 2008
    I have done the vacuum bit without improvement
    Still I suspect opening case needed
    Not being a technician a referal for expert work needed?
    Or Having mechanical ability, suitable instruction detail would work?
  • Lionroy Feb 20, 2008
    Obviously a lot of persistence and patience is required!!
    I will give it a shot
    President:
  • 2,072 Answers
Sometimes what happens is the toner seeps onto and into places where only a vacuum and crevice tool and a brush will remove it.
It will get anywhere and everywhere, and wind up on the strenghtning flanges, it can be tricky and frustraiting to remove all of it.
Persistance and a smaller vacuum will most likely be what will allow you to resolve it.
Also take a look at your toner cartridge and be sure it is not leaking. There is no use going through all that, only to have it come right back.
Posted on Feb 19, 2008
  • Rick Kasper Feb 19, 2008
    The areas you need to vacuum would be those areas you can access by opening all latches, and removing all cartridges.
    Just be cautious and make sure you open all covers and chutes.
    Note how the cartridges remove and install.
    I really want to stress to look for a leaky cartridge. They will develope weak magnets and worn blades from time to time that will cause toner or developer to leak out.
    At times, no matter how much you vacuum, wipe, ect, you may just have to run it out. I have had times when I just couldn't get all the ink out and had to settle for running the machine until it ort of self cleans.
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
I have a Brother HL1240 printer. When I print I get toner stains on the left margin. Is this a cartridge problem or is it the printer itself? I guess I'm wondering if I change the toner cartridge...
in most case this kind of issues arise if your drum is not cleaned properly with the wiper. As the printer becomes old, the wiper that cleans the drum might get reduced in size...
so it has to be checked at the first.
May 23, 2011 | Brother HL 1240 Printer
I HAVE BLACK ON THE ENTIRE LEFT SIDE OF THE PAPER. About a 1 inch margin on the whole left side of every page has black on it.
Looks like a defective drum unit. Take out the drum with toner and look at the shiny (usually) green cylinder on the bottom. If it's constantly covered with toner, it means that either it got dirty from something or the silicone gasket strip that removes the toner from it is "leaking".
Remember that the green drum is very delicate and should not be exposed to light for a prolonged time. If you want to try and clean it, use the softest cloth or tissue you can find, dampened slightly in isopropyl alcohol, and use very delicate stroking motion, applying nearly no pressure.
Oct 24, 2009 | OKI B4350 Laser Printer
Panasonic KX-FL521 Fax Laser Copier, New Toner
This is usually an indication that the toner cartridge wasn't shaken from side to side to distribute the toner evenly.  If this was done, the cause is probably a dirty drum.  Remove the toner cartridge and clean the drum. Either of these two solutions should solve your problem.  Best of luck.
Greg
Jul 09, 2009 | Panasonic Office Equipment & Supplies
The printer is printing lines across each page (usually one of each toner color, sometimes only black)
the toner cartridge is near to empty so the powder collected on the wastage side is getting leaked when ever you give a printout and that leaked powder creates a line on the paper. or there is a dust collected in the lower area of the printer by the leaked tonner. replace the cartridges or get refilled it properly.to make this problem clear.
Nov 17, 2008 | HP Office Equipment & Supplies
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Printer problems
PULL OUT TONER CARTRIDGE SHAKE SIDE TO SIDE AND REINSTALL
Jan 18, 2008 | Brother MFC 9700 All-In-One Laser Printer
Shadow On Printout
Here are the possibilities:
-drum blade is not cleaning well, take out toner look at the shiny cylinder ( drum) is there toner on it? change cartridge.
- transfer roller ( black roller on bottom of machine that comes in contact with drum) take lint free cloth and wipe may need to be changed,
Oct 11, 2007 | HP Color LaserJet 9500HDN Printer
Panasonic KX-P7100 Laser Printer Logo
76 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
