Question about Samsung LN40A450 LCD TV
I have a Samsung LN40A450 LCD TV that is only a year and a half old. I am getting no power to the tv only a consistent blinking red light and a audible clicking/beeping noise. What needs to be replaced?
  • 233 Answers
I will explain how to:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.(see picture below)
  • Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated (see picture below)
  • Replace the damaged capacitor with the same value that you can see on the surface of the capacitor. (In this step you need any soldering tool)
My advice: replace capacitors with higher voltage, like 10V replace with 16V or 25V will be fine.
Posted on Feb 10, 2010
  • Samsung Master
  • 1,684 Answers
Yes,
The capacitors on the power supply are the cause of your problems. This model is well known to have issues with the power supply board. Here is a picture of the power supply board with the problem capacitors circled.
And here is a link to a parts kit of capacitors to do the repair.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_92&products_id=204
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Feb 17, 2012
I have a Samsung LN40A450 LCD TV 42 that is only a year and two months. No power to the tv only a consistent blinking red light.
I solve my problem, changing , 2 - 10Vx1000Mfd ectrolitic capacitors of the power supply.
My TV is OK.
Tanks a hundred times for the indication.
Arinto Cruz,74 - BRASIL
Posted on Mar 26, 2010
Samsung UN55FH6003FXZA won't turn on even though the red LED on the front is lit showing power is available. It did have a long delay to turn on, now not at all.
Samsung TV won't turn on + blinking red light (explained fix ...
? 4:03
https://www.youtube.com/watch?v=wEWzYLaKdgU
Aug 29, 2014 - Uploaded by Mysimplefix
(CC) (HD) A step-by-step repair video, showing the replacement of swollen/shorted "electrolytic capacitors ...Missing: un55fh6003fxza
bout 1,270 results (0.53 seconds) Search ResultsSamsung LCD TV LN32A330 power won't turn on - Forums - CNETwww.cnet.com > Forums > SamsungCNETMy 1 1/2 year-old LCD TV model LN32A330 won't turn on by direct and remote today. The red stand-by light is lit, but never blinks and the TV won't power up. A..Samsung UN55FH6003FXZA BN94-06418R Main Board ...www.shopjimmy.com/samsung-un55fh6003fxza-bn94-0641...ShopJimmyThis Samsung UN55FH6003FXZA BN94-06418R Main Board IC901 EEPROM ONLY ... TV won't turn on after being off for 30+ minutes - TV shuts off by itself
Jan 05, 2016 | Samsung Televison & Video
I have a samsung LN40A630 from 2008. Won't power up.
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 01, 2013 | Samsung LN40A450 LCD TV
Watching tv last night, the tv turn off by itself with out touching remote control, after that i keep trying to turn it on and the on/off red tv light startted flashing for a few minutes until it when off...
It can Have one of 2 Troubles, The Inverter Board is Defective or the Power Supply has bad Capacitors. I found 3 Capacitors known to go bad in that set. Replace the 10 Volt Capacitors with 16 Volt Caps and they will last forever.
Oct 07, 2010 | Samsung LN40A450 LCD TV
My wifes phone hit the tv screen. We get no picture.
do you get an error message in the form of a blinking power button the blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
May 30, 2010 | Samsung LN40A450 LCD TV
LCD TV samsung LN40A450 doesnt turn on
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
Jan 18, 2010 | Samsung LN40A450 LCD TV
I have a Samsung LCD TV, model # LN40A450 with a PC input. I connected my Dell Vostro 1310 laptap to the PC input and I consistently get a "Mode Not Supported" message on the TV screen. Why? I had a...
You TV will only accept specific signal formats (modes) through the PC input. Check you user manual for compatible modes. You then need to set screen 2 (your laptop VGA output) to 1 of the compatible formats (PC display settings). A common format/mode example would be 1024 x 768. Try it out and see if you get a picture. You can then increase the resolution 1 at a time to find the best format/mode for your purposes. I hope this was of some assistance.
Dec 29, 2009 | Samsung LN40A450 LCD TV
My tv wont turn on red light keeps flashing
there are two 1000uF 10V bulging capacitor in powersupply board.
replace with 1000uF16v or 25v.you will save $200.
Oct 30, 2009 | Samsung LN40A450 LCD TV
Hi my samsung lcd tv model le40s8, it won't switch on when i press the power button on the remote the red light starts to flash and it makes a clicking noise and won't turn on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Aug 17, 2009 | Samsung LN40A450 LCD TV
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Samsung LN40A450 LCD TV Logo
1,907 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
