Question about Dell Axim X3 Pocket PC
Wireless connection I have Dell Axim 30. For some odd reason I can't get the wireless to connect. I don't know if the settings are right. What are the settings suppose to be. I have a Linksys wireless router
  • coreykirk Nov 02, 2008
    can not get wireless internet to work
  • tompiano Feb 08, 2009
    I just purchased this Axim X3 used. I used to have the X5 model, but now I have the wi-fi possibility. I've been able to connect at a few places, such as Starbucks, but can't seem to get connect around my house, which has a wireless network.
    How is the unit to be configured?
    Tom
    Sergeant:
    Champion:
  • 317 Answers
Check to make sure that the wireless key is set to WEP and not WPA. If it is a WPA, then you won't be able to, as the Dell Axim's don't have enough security certificates to access WPA networks.
Posted on Feb 21, 2008
Had dell axim51 for years...never was able to connect to wireless or any internet
The way to connect to the internet with you Axim is dependant on the wireless router setup.
for instace if the wireless is set up for WEP encryption there is a ( I think) about 8-10 hex chacters(0-9, A-F) that needs to be entered to connect. You will need to find these on your router.
Other system that are not protected should have no problems. connecting
hit the broken bars and the lower right corner, then hit the turn on button, then click on the site tab, this hould show you what networks are available. It will tell you if it is protected or is an open network.
This unit will only connect to 802.11 B wireless networks.
Aug 28, 2011 | Dell Axim X51v Pocket PC
Dell Axim X5 connecting to Belkin wireless router
What is the model of your wireless router? Does it support the B network your pda is?
also try installing ministumbler (wireless scanner program) to the pda
available on this webpage
http://www.stumbler.net/
scan around with the stumbler it should detect the network, if its set to the wrong band, G only for example it wont be detected set the router to mixed B / G mode.
Aug 13, 2008 | Dell Axim X5 Pocket PC
I have tried and tried and cannot connect to the internet on my dell axim x51. Any solutions?
This depends entirely on how you are connecting to the internet.
If you are using wireless in your house, make sure its not protected with WPA encryption, change the wireless encryption to WEP if you are using encryption. - for wireless wlan you would need a add-on Wireless adapter. if you are using bluetooth, then the settings on the computer - internet connection sharing is probably not turned on.
I can't go into detail now since this is complex and I don't have much information to work from.
this device is not easy or simple to get connected to the internet without connecting it to your computer with a data cable. with a data cable it should work instantly, if not then some settings might need to be changed.
Aug 07, 2010 | Dell Axim X51v Pocket PC
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
Cant connect to internet using my dell axim x30 helppppppp
http://www.fixya.com/support/t1775615-connect_internet
just answered this for someone else, if you have any other problems get a hold of me on twitter @clarkb16
Feb 23, 2009 | Dell Axim X30 Pocket PC
I want to connect to my wireless Internet connection
If everything is working as it should. All you have to do is turn onyour Wi-Fi. You will then see a popup asking you if you would like toconnect.
You may need to add a compact flash wireless card:
  • http://wifi.aximsite.com/wifi-faq.html#_51-card
  • http://www.amazon.com/SPECTEC-Wireless-Networking-Connection-Notebooks/dp/B000BD9PBQ
You'll find a comprehensive axim wifi guide here: http://wifi.aximsite.com/
Oct 28, 2008 | Dell Axim X30 Pocket PC
Dell axim x5 1180 truemobile wireless issues
Only WEP is supported------- also download the rom patch for this card off of the Dell site.
Oct 04, 2007 | Dell Axim X5 Pocket PC
Wireless connection problem
Your buggered lol got same problem :( Ive looked into it got latest drivers and its netgears fault. Apprently you require their adapter for laptops etc exepct laptops connect because i dunno, but pda devices wont? Yeah i dunno its odd :S Im temp switching from wpa to wep for my pda that works :D
Sep 21, 2007 | Dell Axim X50 Pocket PC
Wireless Connection
Hi Joe, Are you connecting to an Access Point on your home network? Are you connecting to a wireless connection in a cafe or something? Either way, you should be able to connect. All you need to do is tap the small symbol on the bottom right of the main screen (looks like a little staircase) and let it do it's thing. It will bring up another screen (WLan Utility). When it's connected, the arrows to the left of the clock will stop moving. If you want, you can click on the "Setting"button where you can perform more diagnostic functions. You might need to type in a network key, but otherwise, you should be working.
Jun 19, 2007 | Dell Axim X51v Pocket PC
Connectivity/activesync and network issues
When using wireless lan with PPC, there are some experience shere with you. 1. You must do an "Reset" after the first time of installing wireless driver into your DELL AXIM. Otherwise, the driver would not work. 2. Microsoft Pocket PC 2002 only can allow one source to access the internet. It can't access internet via the USB and wireless at the same time. Thus, it is more batter way to leave your AXIM alone instead of insert on cradle when you try to access internet via wireless lan. 3. Some of the wireless's CE driver are based on StrongArm, 206MHz, not PXA250, 400MHz. It will got problem when the wireless try to initiate the link between base station and PPC. Try the following step: (i) Make sure you have been install the wireless driver. (ii) Remove your wireless from CF slot. (iii) start->setting->power->processor select "PowerSave" mode and apply it. (iv) Plug wireless into CF slot (v) If you can get an dynamic IP or access internet, you can repet step 3, but select "Auto" mode. Hoping these information can solve your problem.
Sep 19, 2005 | Dell Axim X5 Pocket PC
Dell Axim X3 Pocket PC Logo
280 people viewed this question
Alun Cox
