Question about Sony (UWP-S1) Professional Microphone
I dont know if it is the receiver or may be the transmitter, but i can see modulation on the transmitter but the receiver keep saying "NOTONE" can you help with this
    Champion:
  • 211 Answers
H,
You can check on your receiver if there's a RF signal.
If so, check the gain setting on the transmitter.
And check also the gain setting on your receiver.
Thats all I can advise on this distance.
Regards,
Gerard
Posted on Feb 01, 2010
Chris Millett I want to know. If I want to turn a 4 meter handheld two way radio into a vhf tv transmitter, can I use radio shack's tv modulator?
It can't be done. You can't turn an audio receiver / transmitter into a video transmitter. Give your head a shake!
Plus if you want to transmit anything especially video over air, you have to be fully licensed and registered.
Apr 29, 2016 | Radio Communications
Tip
Do it Yourself: Reprogramming the Remote Keyless Entry (RKE)
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Jeep Grand Cherokee Alarm System (1993-1998)
I would try reprogramming the Remote Keyless Entry (RKE) transmitters before looking for anything else. Make sure the batteries in the RKE transmitters are good and replace them if in doubt. Here's the procedure for programming the RKE transmitters.
Up to 4 Transmitter Identification Codes (TIC's) can be programmed into the receiver at any given time.
1. Open the driver's door of the vehicle. Leave it open through the programming procedure.
2. Move the mechanical door lock lever to the LOCK position.
3. Insert the ignition key and turn it to the RUN position.
4. Turn the ignition to the RUN position. Within 20 seconds, aim a transmitter at the receiver dome and press the lock button, for at least 5 seconds. Once the receiver accepts the programming code the driver's door will unlock.
5. Once the first transmitter has been programmed, additional transmitters (up to 4) may be programmed into the receiver. Within 20 seconds of the previous transmitter programming, move the mechanical door lock lever to the Lock position. Aim another transmitter at the receiver dome and press the LOCK button for at least 5 seconds. The door lock will cycle again.
6. To lock the programmed codes into the receiver, the ignition must be turned off and back on within 20 seconds after programming the last transmitter's code. At that time, all previous codes are erased from the module.
If the alarm still doesn't work correctly, you probably have a bad Alarm Module. If you wanna download this procedure, clic the image.
Enjoy Jeep.
on Sep 23, 2009 | 1993 Jeep Grand Cherokee
Keyless receiver
immobilizer control module under the dash.some vechicles if you replace key remote dealership has to reprogram remotes using diagnostic equipment.try this techinique to synchronize remote transmitter. stand within 5 feet from vechicle .press transmitter lock and unlock buttons simultaneously for 7 seconds . system will lock and unlock doors confirming synchronization. if this dont help dealership has to reprogram remotes.
Dec 13, 2013 | 1997 Chevrolet Blazer
I have a 2004 GMC Envoy with 6 cyl engine. Both remote keyless entry went dead at same time and now I can't unlock the back hatch door. I had to release it manually but the sensor keeps locking it back....
Take it an have it check at a qualified repair shop for DTC'S - diagnostic trouble codes . Could have problem with the liftgate/endgate module. Don't try guessing to find a repair .
The keyless entry system has the following main components:
• The transmitters
• The endgate module (EGM) (XUV only)
• The liftgate module (LGM) (Except XUV)
When you press a button on a transmitter, the transmitter sends a signal to the liftgate module. The module interprets the signal and activates the requested function via a class 2 message over the serial data line.
Do you know what class 2 serial data communication network is ?
You need a scan tool to program the remotes .
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
Close the lift gate.
Ignition ON, access the scan tool Liftgate Module Setup menu and select Program All Key Fobs.
Follow the the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
Operate the transmitter functions in order to verify correct system operation.
012 GM Class II Communications
Jul 25, 2017 | GMC Envoy Cars & Trucks
I have a 2006 Chevrolet Malibu and the keyless entry started working intermitantly and now randomly works maybe once a week. It wont pop the trunk or lock or unlock the doors. I replaced the batteries in...
Unfortunately you may not have a choice in the matter ! You have no idea of the electronics involved here . No one knows your GM vehicle better . And $ 85 dollars is a heck of alot better then $115.00 dollars a flat rate hour . Pep boy's , firestone , AAMCO .
• The transmitters
• The body control module (BCM)
• The remote control door lock receiver (RCDLR)--When you press a button on the transmitter, the transmitter sends a signal to the RCDLR. The RCDLR receives the signal and sends a X Link serial data message requesting the appropriate function from the BCM.
Customer Programming Method for Enabling/Disabling the RVS Feature
Using the driver information center (DIC), the RVS feature can be DISABLED and ENABLED just like other items programmable via the DIC. When a lock control, entry-remote entry, extended range (AP8) equipped vehicle has RVS added to it and the vehicle is not DIC equipped and the customer wants to disable RVS. The dealer will perform the DISABLED remote start function since the owner cannot perform the function on thier own without a DIC.
Important: All transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon receipt of the programming signal from the first transmitter.
Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed. All doors must be closed to perform this function.
Install CANDI module.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Vehicle Control Systems.
Select Computer/Integrating Systems.
Select the proper engine size.
Select Module Setup.
Select Body Control Module (BCM).
Select Program Key Fobs.
Follow scan tool on screen instructions.
Remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
May 04, 2017 | 2006 Chevrolet Malibu
How do u turn up a galaxy dx55v.
Hi, my name is John. Welcome to FixYa. Take off the cover, with the circuit side down, take a plastic tuning tool, you can get one at your local electronics store. turn your channel select to midway of the band. make sure your modulation is turned off. Key your mic and tune VR13 to the Maximum on the watt meter. this is for the power. Next, locate VR14 turn the modulation up, and say ahhhhhhhhh, repeat if needed. Thanks for choosing FixYa....John
Dec 01, 2010 | Galaxy Radios DX-55V Base CB Radio
1997 jeep will not start thinking its the anti theft lock but dont not how to reset the code ... does anyone know how
Click here also; http://www.scribd.com/doc/20110658/Keyless-Entry-System-Jeep-Grand-Cherokee
Oct 05, 2010 | 1997 Jeep Cherokee
Need to know how to program keyless remote on 98 cavalier
1997 Cavalier remote keyless entry programming.
All Remote Keyless Entry Modules may be programmed to receive four different
transmitters which all may be used to operate the remote control lock system on the
vehicle.
Also, severalvehicles, each with the same system may all be programmed to operate from the same transmitter or four different transmitters.
Step 1. Turn ignition off
Step 2. Ground the program pin.(within one second, Lock, Unlock and Trunk will cycle to indicate module ready for programming.)
**the program pin is the two wire connector plugged into the RKE reciever in the trunk of the vehicle at the Left Wheelhouse. Leave the main harness plugged in but unhook the two wire connector and ground the pins.**
Step 3. Press and hold the LOCK and UNLOCK buttons until:
Lock, Unlock, Trunk, and Horn cycles to indicate the transmitter has successfully been programmed. (This takes no more then 12 seconds)
Step 4. Repeat step 3 for the remaining number of transmitters
Step 5. Remove the ground from the program pin.
Step 6. Verify proper operation of the transmitters.
Keep in mind that 97-99 can be programmed by the owner, 00+ require DEALER programming with the scantool.
I hope helps with this (remember rated this help) Good luck.
Dec 29, 2009 | 1998 Chevrolet Cavalier
"NOTONE" Error Message.
I had this problem once and it was a malfunction transmitter circuit board. Had to call Sony service to replace the board.
Try another transmitter to help confirm the receiver is functional.
Mar 22, 2009 | Sony (UWP-S1) Professional Microphone
My remote door locks dont work with the remote
hi,problem with remote key,you check the battery of the transmitter,fine,how about trying with spare key,or check fuse or send to dealer for proper diagnose,preventing wrong part replacement.
Feb 19, 2009 | 1994 Mercedes-Benz S-Class
Sony (UWP-S1) Professional Microphone Logo
210 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
