Question about Samsung ML 2010 Laser Printer
Samsung ML 2010 solid red light online/error, new toner, 5 month old only please help
SOURCE: Waste Tank Full - Solid Red Light
Technically you do have to buy a new toner tank (they come in packs of 3, Harvey Norman normally stock them), however the carefull application of a vacume cleaner (use disposable vacume bags to do this, cloth bags don't filter well enough) to the full waste tank can at least double its life if not more. You will only be able to do this 2 or 3 times but in a pinch it will let you resume printing for a while. It allso helps to clean the optical sensor windows (their the only optically clear plastic bits on the cartridge so hard to miss) with a cotton bud (a DRY cotton bud). You will need to clean both sides of the window portal from the inside of the wate tank as well. Bending one end of the cotton bud at a 90deg angle will help when doing this. It's fiddly and potentially very messy work if your not carefull so be prepared to make a mess and most importantly keep the vacume nozle near the opening of the waste tank to **** up the super fine waste toner powder.
As for if this is just your printer wasting toner, no its not. If the printer did not clean its roller after every colour print you would end up with colour contamination on the following pages. Hence why colour prints take longer than black.
Posted on May 09, 2008
SOURCE: Samsung ml 2010
i want driver of ml2010
Posted on Jun 26, 2008
SOURCE: Samsung ML-2010 won't feed paper
I now understand the cause of my very loud, rattling sound. Each time a page is fed into the printer, the pickup roller makes a complete rotation. At each end of the rod through the paper roller is a cam. If I'm successful, I will upload a picture of the right one (looking into the printer). For each cam, there is a roller that must move down by a few milimeters so that the cam can reposition itself. In my case, one of the rollers is almost completely rigid, so that the cam is stopped a few degrees short of returning to its initial position. I have also posted what looks like a conspicuous asymmetry. The next two images are the LHS (nonrigid) and RHS (rigid) sides. It looks as if there is a piece missing on the side that is rigid. I think a thin plastic piece has fallen under the plate carrying the roller so that, on one side, it cannot depress. I also have a very funky solution. I simply removed one of the phillips-head screws on the back of the printer (on the side that is rigid). Now the plate with the roller seems to have just enough flexibility to allow the cam to reposition.
Posted on Sep 21, 2008
bhagyavichar
  • 414 Answers
SOURCE: Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Posted on Oct 26, 2009
SOURCE: Samsung ML 2010 Laser Printer Red light
Posted on Jul 23, 2010
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
The online light stays red and I can not print anything. what should I do?
check the toner cartridge. red light means there is an error in the printer. check for any paper jams. check paper tray settings.
Oct 01, 2010 | Samsung ML 2010 Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
On Line / Error light red and printer can't work on ML 2010
Derek Kwaku Asamoah box mc 279 Takoradi. Please am using your product "samsung ml-2250 printer" and the problem is that the online/erro light is on. thank you for your co-operation and i hope to hear from you soon.
Jun 08, 2009 | Samsung ML 2010 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Feb 24, 2009 | Samsung ML-2510 Laser Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
On line/error light
The online/red light would only come on if:
1. there is no paper;
2. missing communication (USB) with the PC;
3. the front door is only partially closed ;
4. if the toner/cartridge is not fully engaged and locked in place; and
5. internal printer error(s).
More often, it is either the door or the toner that causes this.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Feb 10, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
1,344 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
