Question about Remington Polesaw Wizard
Oil leaks out as fast as it goes in - Remington Polesaw Wizard
    President:
  • 2,220 Answers
You provide no model number. That forces me to make my best guess. I opted to use model number “104316” as described below:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNo" into the "Search for your unit by Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
I opened the "YourModelNumber”parts list and found the oil tank pn ”079086-02.
I typed that into the “Search for your parts by Part #:” window and it said replaced with pn “108639-01. I input in the part number window and found; “Back Ordered Forever”. You might try an Internet search for "Remington 108639-01".
I searched for the oil cap and found 107512-01 $4.72.
Your Owners Manual is not very detailed, this excerpt is from a different model RemingtonPower saw.
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil. Note: For
temperatures below 30°F, use SAE #10 oil. For
temperatures above 75°F, use SAE #40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for
good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
Note: It is normal for oil to seep when saw is not in
use. Empty oil tank after each use to prevent seepage.
If you use a lighter weight oil it may contribute to this. If your oil cap has a leak to atmosphere that might also cause this. Try rubber banding a sandwich bag over the filler hole as a seal, better? Replace the cap. No better the tank is leaking.
The really bad news is RemingtonPower is no longer in production and eBay is the only source for some replacement parts, like this tank.
I am not affiliated with RemingtonPower and spent a fair amount of time providing this answer to you. I should not be punished because you are disappointed with results beyond my control. A good rating and perhaps a few kind words from you are my only payment for this service. Sorry
Lou
Posted on Feb 02, 2010
1998 Dodge neon..fast oil leak
bad seal. have you looked under car and see from where the leak is coming?
Feb 18, 2014 | 1998 Dodge Neon
Idle races too fast 1200-1500rpm
at first glance not having a model or serial number it sounds like a vacuum leak, ignition malfunction or issues with the governor.
Oct 31, 2017 | Delco Heating & Cooling
Fast leaking oil
fast leaking oil? what is it you are trying to get help with, all you listed was fast leaking oil. is this a car or truck?
what year,make model and engine size is the car or truck and in what area is the oil leaking?
a motor or transmission can leak oil for many areas. give me a little more info and i will try to help you locate and maybe repair this fast leaking oil problem.
good day
Mar 31, 2013 | Cars & Trucks
Duo fast leaking oil
putting to much oil into tool ( it just takes a few drops a day) or cap/ nose has loose screws
May 05, 2012 | Duo Fast Duofast Cn325 Cn350 Nailer Oring...
I own a 2002 VW Passat with 110,000miles that that is burning oil so fast that I have to put oil every month. First the "STOP Oil presure issue" light comes ON and then goes away then engine...
YOU MIGHT HAVE VALVE SEALS LEAKING BUY OR THE PISTON OIL RINGS HAVE GONE BAD THATS TWO PLACES TO START ALSO CK THE PCV VALVE THAY ARE NOTORIOUS FOR LETTING OIL GET BY
Apr 22, 2011 | Volkswagen Passat Cars & Trucks
2001 f150 super crew oil light comes on at low rpm goes off when i accelerate"
you must obtain an oil pressure gage you can use a inexpensive type like you would hang under your dash. remove the oil pressure sending unit from the engine, a little oil will leak out when you remove it, no big deal. install the add on gauge and see if the pressure at idle with the engine warmed up is over 20 lbs. if not you probably have bad crankshaft bearing but you would want to see what htings look like inside the oil pan.if the pressure goes up to about 60lbs when running fast. and is very low at idle the engine is probably worn out. if the oil pressure drops when it is running fast you may have a plugged oil screen.i have found paper towels and rags inside of engines.
Feb 21, 2010 | Ford F-150 Cars & Trucks
Small oil leak coming from trans area
cant help you with the radio that sound like a wiring problem and thoose are hard to diagnose over a computer but the oil problem... if the oil is comming from the back of the engine were the trans meets then the rear main seal is leaking. You can do one of two things. Yo u can pull the trans and replace the seal on the engine or you can go to a parts store and get a bottle of "LUCAS" oil stop leak it will seal it up for you. and for the next 3 oil changes make sure you put a bottle in the oil. this will not harm the engine or any other componants in the car. i recomend "LUCAS" brand because its the only stop leak i've ever seen work so fast and i've never had anyh comebacks at my shop for this problem
Jan 14, 2010 | 1989 Ford Crown Victoria
There are two medals hoses that run into the radiator of my chevy lumana one is leaking oil is it an oil line?
the steel lines that run into the radator are tranny lines. if there leaking I would have that fixed soon.
Nov 10, 2009 | 1995 Chevrolet Lumina
Mot failure emmisions
Internal oil leak, change the spark plugs and cables, oil, filter and add Lucas oil. Take the car for inspection and let me know how it goes. For the belt depends where you get the parts and who does the work.
May 15, 2009 | GMC Yukon XL Cars & Trucks
Remington Polesaw Wizard Logo
293 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
