Question about NEC SuperScript 870 Laser Printer
Order supplies I need to order toner for my 870 laser printer
    Genius:
  • 3,587 Answers
Go to google.com and type in toner cartridge and the model number. I'd be astonished if you didn't see dozens of em.
got backup for your computer?
Posted on Feb 19, 2008
Where to purchase or fix a Minolta Di251 polygon motor?
Can't fix a polygon motor need to order the entire Print head which houses the LASER and polygon motor. try web site below if they have one Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 18, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
DRIVER FOR PRINTER NEC870 x WIN7 x64
You could try use the Windows XP SuperScript 870 driver or you could install the HP LaserJet III printer driver. It should work with your printer, but may have limited functionality.
Feb 08, 2010 | NEC SuperScript 870 Laser Printer
How do i manually rotate cartridge carosel
You don't want to rotate the toner cartridges, you need to get a new Drum Cartridge assembly.
When you get that, it will have detailed directions, but you'll end up opening the top of the printer and pulling the drum straight up.
This is a different component than a toner cartridge. The toner carts are the supply of new toner. The drum cart collects excess toner during the printing process, and when it's full you need to get a new (empty) one.
If you connect to your printer's web interface it will have a link for "order supplies" that will take you right to the dell.com page for it.
Post a comment back if you need me to get the URL, and I'll grab it from my printer when I get home tonight.
Sep 02, 2009 | Dell 3010cn Laser Printer
DELL 5110CN 093-426? What error is this?
093-426 is a "black toner replace soon" error message. first make sure that you're using a dell-branded toner cartridge (you can order online here: www.dell.com/supplies) & you can try reseating the black toner cartridge.
Jul 13, 2009 | Dell 5110cn Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
My NEC 870 laser printer has paper jam. How can I fix it?
Open the top printer door by pressing the round release button on the left side of the printer. Remove the toner cartridge (numbered 2) and the photoconductor cartridge (numbered 1) from the printer. This will give you full access to the paper path and you should be able to remove the jammed paper. If you pull on it and it begins to tear or is feels like it is caught on something, remove the paper and paper tray from the front of the printer and try to reach and remove the jammed paper pulling it back out the direction it went in.
With the jam removed, replace the paper tray and paper, re-install the photoconductor (#1) and the toner cartridge (#2) into the printer and close the top door. Make sure you get the door closed firmly and that it catches otherwise you will still have an error light and not be able to print.
That should fix your problem... good luck! :-)
Jan 31, 2009 | NEC SuperScript 870 Laser Printer
Toner order #
the part you would like is DQ-TU10C -- Toner Waste Container included
if your in canada i can refer you to a number
Aug 25, 2008 | Panasonic DP-1810F Laser Printer
Prints what looks to be bar code
I have the same problem. I have replaced both toner and photoconductor, did not solve the problem. I have been using XP for some time before my printer started acting up.
Feb 21, 2008 | NEC SuperScript 870 Laser Printer
Waste Toner Light won't go off?
The waste toner is usually a bottle near the toner cartridge which collects excess toner powder from the cartridge. It is usually present in more heavy duty laser printers, not all printers have them as a replaceable supply. You would need to refer to your manual for replacement instructions, they vary from printer model. For this machine, the Waste Toner supply number is #420131. In the case of the first poster, my best guess would be there was spillage of toner on the sensors to detect the waste basket overflowing, hence why the error message is constant. This would require cleaning of the sensors, a relatively simple task but for proper access, the machine would need to be partially disassembles for thorough cleaning. It would be best done at a repair centre.
Aug 04, 2006 | Ricoh Aficio CL2000N Laser Printer
NEC SuperScript 870 Laser Printer Logo
60 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
