Question about Westinghouse LTV-27W2 27 in. HD-Ready LCD Television
After playing for 1 to 2 hours screen turn white, but can still see picture need help
  • 10,594 Answers
If it is Westinghouse LTV-27W2 tv then check/ replace T-Con board that can be cause of this kind of problem.
T-Con board is located at top center if you see tv from rear, its usually covered with metal shield and very much care is required to handle this board.
Local tech will help you if you feel uncomfortable working in tv.
Thanks.
Posted on Feb 01, 2010
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
WHITE SCREEN NS-P10DVD11 PLAYER....Plays sounds no picture....Has a 1 year warranty...can i get a replacement..
The fault is with its video processor section. If the set is in waranty period, it will be best for you either get it repaired by its authorised service center, of replaced it by an other one. The second stated will be best, rather than get it repaired as it is new.
May 22, 2012 | Insignia IS-PDVD10 Portable DVD Player
My PDV-088PT White Screen?
The video processor has failed, or the LCD panel display, either way the cost to repair cannot be justified.
Apr 09, 2012 | Polaroid PDV-088PT Portable DVD Player...
There are marks on my LCD 42" TV ,its on the screen itself.It looks like water marks.It started of small marks and it then it getting bigger.
Things You'll Need:
  • Burn-In Reduction Screen Saver DVD
  • DVD Player
  1. Instructions
    • 1 Plug DVD player into your TV and power on. Make sure you plug the right component cables into their corresponding inputs on the back of the TV. This is usually done by simply matching the colors of ends of the cables with the colors of the input holes on the back of the TV.
    • 2 Turn TV to the proper input to display the DVD. Make sure there is not a DVD in the player.
    • 3 Place burn-in reduction screen saver DVD in the player. Allow a few seconds for the DVD to start playing. A pattern of white "video snow" will appear on your screen. The entire screen should be taken up with this patterm.
    • 4 Run the DVD for at least several hours; this will help wear the TVs phosphors evenly. Depending on how long the image has been burned into the screen, the amount of time you should play the DVD varies a lot. A good rule to follow would be to play the DVD at least four times the period the image has been displayed. If you have an image that has been on the screen two hours a day for a whole month, run the screen saver for at least 240 hours
Jan 17, 2011 | Televison & Video
When TV is turned on, there is no picture but a very, very faint verticle haze in the middle of the screen. At first, the power switch lamp is green and blinks slowly, then at a faster pace. At the same...
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Jun 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Toshiba plasma blank screen
your video card needs replacing, 75.00 plus labour
Jan 24, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Samsung logo
How old is the set and what kind of TV is it? LCD,plasma, direct view?
C-Dog
Feb 12, 2008 | Televison & Video
LCD TV White Screen
do you still have this tv? what happens if you hit the info button - does it bring up the banner at the bottom of the screen?
Dec 30, 2007 | Televison & Video
Venturer 19" lcd tv
i have the same problem, i don't no what to do. Its so annoying. It randomly worked once and then the same thing happened again.
Nov 22, 2007 | Televison & Video
Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
