Question about Optoma H31 WVGA 480P Native EDTV DLP Projector Multimedia Projector
Color The color goes in and out and the image is flickering occasionally.
    Problem Solver:
  • 11 Answers
Hi, If you have tried other video sources & still get the same results. It sounds like the motor that turns the color wheel is going bad, These motor's run from 5,000 to 10,000 rpm depending on model & are usually the first point of failure in a color wheel based DLP projector, If you don't count the lamp.
Overtime it may begin to make a squealing noise. Usually you can find replacement motors on the internet by searching the part number printed on the motor google is great for searching part numbers.
Posted on Feb 19, 2008
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Mitsubishi VS 45607: 1. TV starts out as B/W when first turned on. After about 30-60 min, the color is restored, although not in the full color spectrum. 2. TV flickers a lot vertically. After about an...
You have a bad video board. If you can find one used it is fairly easy to replace once you get into the TV itself. Your color guns could also be adding to this problem. I am not familiar with this television and its components so I dont know if you can replace one color gun at a time or if once one is shot then all three have to be replaced. That should be a start for you anyway.
Feb 25, 2011 | Mitsubishi VS-45607 45" Rear Projection...
Toshiba 32A35 Color TV Flickers & Scrolls w/ light colored images
My Toshiba 27" tv has the exact same problem any solutions out there or is it time to toss the tv?
May 24, 2010 | Toshiba MV19H1 Combo
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Optoma H31 WVGA 480P Native EDTV DLP Projector Multimedia Projector Logo
187 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
