Question about RTO Image 15.0R Treadmill Walking Belt
Treadmill Walking Belt Model 470 CX petl 499051
I can't find in the shops the belt for this model
  • 79 Answers
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Hi, our proform 790 tr treadmill is aorund six years old and the walking belt and height motor seem to be going. Is it worth replacing these and is it fairly straightforward?
Changing a walking belt takes about an hour for someone who has done it before. Check the walking deck for scratches, damage as well. Often times if the belt is worn out, the deck needs to be replaced as well. Belts vary in price depending on the make and model of treadmill. Parts can be ordered by calling the number found on the model number sticker on the treadmill. There are 10 different machines with the 790t model name. To get the correct parts find the actual model number (will start with "H"). The parts come with replacement instructions.
Belt $105 Deck $190
As for the incline motor, it is very rare to change that part. It may just require calibration. Start the machine . Press incline up and hold, remove the safety key. Now reinsert the safety key. The machine should rise to full incline then back down to minimum. Once the cycle is complete, the treadmill should work normally. If the incline sensor is defective, the motor will have to be replaced. Incline motor $150.
Feb 26, 2011 | Proform 790T Treadmill
Where can I buy a replacement walking belt for a Precor 9.21 treadmill?
FitnessRepairParts.com has a walking belt for Precor 9.21 treadmill (it says it is used on four different versions of the 9.21... make sure your specific model number is listed)
Jan 12, 2011 | Precor 9.21 Treadmill
ProForm 380i Treadmill: How to repair frayed edge of Walking Belt
Discription: WALKING BELT W/FASTENERS, Part # 193575, Model # PCTL49820, Price $48.83
In humble opinion you should replace the part, it sounds like an accident waiting to happen Call Icon Fitness @ 800-999-3756 and give them the info above.
Jul 18, 2010 | Proform 380 Treadmill Walking Belt
Belt is off alignment
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 31, 2010 | Proform 730 Folding Treadmill Model...
How do you adjust the slack on the belt? This is for a 815 model.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 04, 2010 | Schwinn 820 P Treadmill Silver Service...
How do you adjust the belt on a PROFORM,( Model #
Unplug unit then, using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Apr 21, 2010 | Exercise & Fitness
How do i change the walking belt on a weslo sl20 model #wltl42070
When you buy a belt from http://www.treadmill-world.com you get complete installation instructions.
Mar 31, 2010 | Cadence Weslo Sl20 Treadmill Walking Belt...
How to do you adjust the belt on a Pro form crosswalk 380? The belt is getting loose and I lost the manual.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
RTO Image 15.0R Treadmill Walking Belt Logo
69 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
