Question about Kenmore Washing Machines
Model 110 20722990 ser. ck 3590340 tp 111 wont agitate spin can hear metallic clicking noise
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990
and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
Since it will neither agitate nor spin, but you can hear a clicking noise, the Lid Switch is probably all right but the Motor Coupler is likely bad.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
If the rubber piece is destroyed, you would hear the clicking of the plastic prongs.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Feb 01, 2010
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Model # 110 20702 991 Serial # CK 5008937 Type 111 Can hear motor running and makes a slight noise also drains but won't engage in washer spin
Hello, Thank You for using FixYa. I will be helping you today.Sounds like a failed motor coupler part number 285753. It connects the motor to the trans. You can lean the unit back to change this part. Remove the pump remove the motor and you will see it.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kenmore 24932 Top Load Washer
Whirlpool Washer not drain, with clicking noise
If it has a filter, clean it out and start again
Mar 15, 2017 | Whirlpool LSR7333 Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
Washing Machines Logo
76 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
