Question about Biostar M7VIQ Motherboard
How can I get the firmware t update the bios motherboard M7VIQ
    Problem Solver:
  • 15 Answers
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
Firmware update ECS G31T-M5
Download the bios update here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=812&CategoryID=1&MenuID=16&LanID=0
Do i have to say what happens if you flash the bios with a wrong one.
Nov 12, 2012 | Computers & Internet
Where I can find last BIOS version for my P5VD2-NVM/S?
Click on Start and then Run.
In the text box in the Run window, type msinfo32 and click OK. This will open the System Information program.
When System Information first opens, it defaults to the System Summary, a short list with some of the most important information about your computer system listed.
On the right side of the program, locate the BIOS Version/Date entry.
This field contains the BIOS version that is currently running on your motherboard.
This field may also contain additional information such as the BIOS date, BIOS manufacturer, motherboard manufacturer and the motherboard model number.
Note: If the BIOS date is shown, it can be useful in determining the current BIOS version from a motherboard manufacturer's website if the version is not clear here.
Write down your existing BIOS settings so you can restore them after you've flashed the new BIOS firmware.
Determine the correct BIOS firmware that you need for your computer.
Check your computer manufacturer's website for this information.
If you have a custom-built system, check the motherboard manufacturer's website for the latest BIOS firmware.
Download the latest BIOS firmware specific to your computer.
Some manufacturers provide custom software that initiates the update through your operating system; others provide a third-party application that allows you to flash the BIOS through DOS.
Run the installer or executable file that you downloaded.
Alternately, if the BIOS firmware update is handled via your operating system, simply click "Update," "Write," "Confirm" or a similarly-named button.
If you are prompted for an installation CD, insert the media into your disc drive.
If the CD contains an "autoexec.bat" file, the BIOS will flash automatically when you restart the computer.
While the BIOS flashing procedure varies, nearly all manufacturers provide detailed instructions for completing the task.
Turn off your computer.
Wait about one minute and then reboot.
On some systems, the flash update will restart your computer automatically.
As your computer reboots, go immediately into the BIOS setup menu and look for an option to "Restore Defaults" or "Load Fail-Safe Defaults."
This will be on the main page or the last page of a tabbed menu.
Navigate using the arrow keys on your keyboard and follow all on-screen instructions.
When finished, save your new settings and then exit BIOS.
Your computer will load the operating system.
http://www.wimsbios.com/recommend/biosagent/ibelowmenu
hope this helps
Sep 18, 2012 | Computers & Internet
Cannot detect onboard sound plz help me
did you updated the correct firmware for your bios, sometimes faulty updates lead to this post me *********** board model and make
Feb 27, 2012 | Intel D101GGC Motherboard
I have a WD 1.5 TB drive my bios thinks it is a 500 GB drive I csant find a bios patch any ideas
1st, go to your motherboard's website and download the newest firmware for your board. After updating the firmware, you can connect your drive again.
If you have the latest firmware already, you can get a USB enclosure for your drive and convert it into an exteranl drive. It will be slower and you won't be able to boot from it.
If your motherboard is simply uncompatbile, there is not much else you can do. You could buy an inexpensive motherboard, they cost as little as 50$, but you will need new ram and a new processor, etc.
Feb 28, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
Where can I find info to setup bios. also how do I upgrade bios
For this you need to know the exact model of your motherboard. Your current BIOS firmware version can be seen in the BIOS setup window itself ( Press DEL key during your system startup to enter into BIOS screen)
Your motherboard should have Flash BIOS so as to upgrade its firmware. All latest motherboards will have this type only. Goto your motherboard manufacturer website and search for latest BIOS firmware for your exact model. There itself you can find the utility required for BIOS. download that utility and using which you can update your firmware. Please do update your BIOS only if it is required.
I hopt his is helpful to you
Dec 31, 2009 | Computers & Internet
Our computer is telling us we need to update the BIOS computer shuts itself off
All BIOS components are serviceable via a firmware upgrade that is known as "flashing" this process is called "updating the BIOS". The process itself is fragile since any power fluctuation during a flash may irrevocably corrupt a BIOS' firmware. Great care will need to be taken in order to safely accomplish this.
This guide will help you flash your BIOS by taking precautions and walking you through each step. Not all computers will have the same BIOS manufacturer, let alone the same process, but many have similar steps and precautions.
Guide: http://www.wikihow.com/Update-Your-Computer%27s-BIOS
Also check with your motherboard manufacturers website for specific BIOS updates and updating instructions. mpawlak908
Oct 18, 2009 | Intel Computers & Internet
Firmware problem with P4M900T-M ecs elitegroup motherboard
Reading that my first thought is motherboard bios or motherboard drivers. because it says firmware, i think bios is the first thing you want to check.
understandable, however a lot of motherboards will now update inside of windows, (although i wouldnt try it inside 7 due to it being a beta), and are protected in various ways from problems. but checking motherboard manual or manufacturers website to see how they do the bios update is always worthwhile. And if your unsure, then safest option is don't. Always worth looking for additional options first.
Thanks for using "Fixya".
Jun 24, 2009 | Computers & Internet
Looking for bios update
http://www.epox.com/USA/downloads.asp
Go to Epox site
Select the file you want to download, in your case BIOS
find your 8RDaI3-pro, its a bit down on the list
klick OK
the site will take you to next level, there u find 2 diferent BIOS-updates, both from 2005, select the one you want and download it'
Nov 21, 2008 | EPoX EP-8RDA3I Pro Motherboard
Jumper configuration for motherboard
Matt,
I don't have a solution for you, but tell K. her sister is looking for her, and to give her a call.
-Laura
Jun 27, 2008 | Biostar M7VIQ Motherboard
Biostar M7VIQ Motherboard Logo
107 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
